Support modal axis & user/local space switching for the shear tool
Confirmed, LowPublicTO DO
Currently the shear tool doesn't support setting the axis XYZ, Local/Global etc. As translate or scale do.
Internally this is supported (the gizmo can do this), however there is no way to access this functionality using keyboard shortcuts.
Note that some design is needed for this task since shear has a secondary axis - unlike most other transform modes.
There will need to be a key assigned to cycle between the secondary axis too.
See: T73879: custom property values not setting correctly via code
Campbell Barton (campbellbarton) renamed this task from Support axis switching for the shear tool to Support modal axis & user/local space switching for the shear tool.Feb 17 2020, 6:14 AM
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.
Campbell Barton (campbellbarton) triaged this task as Low priority.
Campbell Barton (campbellbarton) changed the subtype of this task from "Report" to "To Do".Feb 17 2020, 6:19 AM
