Documentation links broken in 2.82 after recent documentation url changes for IO addons #74017
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
7 Participants
Reference: blender/blender-addons#74017
Operating system: all
Graphics card: all
Broken: 2.82 official release
Worked: 2.81
Lots of documentation links for addon regarding import/export are broken, because of some recent change generating documentation.
For example https:*docs.blender.org/manual/en/dev/addons/import_export/io_scene_gltf2.html is changed to https:*docs.blender.org/manual/en/dev/addons/import_export/scene_gltf2.html, but all links in documentation addons are still with io_
I think the change must be reverted in documentation generation, to have some OK links in official 2.82
I checked the link few days before release on Feb. 2nd, and it was OK (cf
42d713b0a6
)It maybe linked to the fact that documentation seems to consider 2.82 as develop version
Added subscriber: @JulienDuroure
Added subscriber: @Blendify
Personally, I would rather not adjust the naming, leaving things as they are even if they are broken.
In the future, we need to not do this, which has to do with implementing blender/documentation#68432.
The 2.82 manual will be archived tomorrow so it is best IMHO to accept the issue and just move on.
Added subscriber: @dmcgrath
I supposed you could also use your .htaccess rights to create some redirects, and fix this yourself? I might need to enable something server side still for that, but in theory, it could allow you to manage your own breakage.
Just a thought!
Added subscriber: @brecht
@Blendify, I don't agree, this seems like a serious issue.
If the change is just the
io_
being part of the page name, why is it hard to revert?Changed status from 'Needs Triage' to: 'Confirmed'
And we should definitely fix the add-ons docs links somehow including
dev
, it should contain the release number for official releases.I took a look, and it appears that mod_rewrite stuff should be part of the
FileInfo
override that we already have in place. So you should be able to patch stuff up in the commits as well.is there a way to add
to
addon_utils.py
? so we canIf not we can manually bump the version with the release but I would rather automate this.
For the moment I am working on a redirect that we can enable for the release
Well, there is rewrite maps which can do a lookup (re: the io_ redirects), but I can't seem to find if anything on if it can dynamically handle just redirects using code (I swore it could, but can't find info), short of just making it a dynamic site with some python code that would need to have an admin reload the server every time you update it. In all honesty, it's hard to beat the performance and simplicity of just using standard file system mechanisms: symlinks, fixed paths, static html, etc.
TBH, I'm not sure that you would want to go that route, regardless. As soon as Python gets involved, I think mod_python in Apache may still be stuck at 2.7? I forget the details, but using mod_python was problematic for us in the past because you can only have one version of it, and we had py2 and py3 code that needed to run, so the only real alternative is CGI type setups, which afaik, don't work with .htaccess rules that you already use for 404's.
Personally, I like the KISS principle for such things. But, feel free to test stuff in a local Apache setup and pass along some config for what you want, and I can possibly accommodate just about anything that works, and is needed/approved.
To clarify on Trouble's comment, I meant to automatically adjust the version number from the addon side instead of the server-side.
@Blendify, maybe something like this (untested):
I have added a redirect so the initial report is fixed. In the future, now that we know can do this, hopefully, create an automated (maybe semi-manual) method to write redirects.
The patch you came up with is something I also thought about so for 2.83 we can do that.
Leaving as a todo to address the URL for 2.83
Added subscribers: @ideasman42, @BrendonMurphy
hi, I think this is not a good solution unless it's temporary. Leading up to 2.82 bcon2, I made sure all addons linked to their correct manual pages. Every included addon should have a permanent page on the Manual.
If this only affects i/o addons then we can simply change the bl_info wiki_url to point to the correct manual page leading up to 2.83.
Adding a duplicate field to all addons: wiki_url and the proposed manual_url are the same thing, an internally used name to point addons to their documentation. @ideasman42 what is your opinion here?
@Blendify
If this change has broken all 2.82 i/o manual links, it will need to be redirected by the manual until 2.83.
I'm happy to help fix the i/o addons current links in 2.83 master, linking them to the new manual page.
The idea with my patch would be to have either a
manual_reference
or awiki_url
for an add-on info, never both. When the add-on is loaded, the URL will then be expanded to include the version.Instead of adding another field, we could keeping using
wiki_url
but have something like this:Which then gets expanded to include the proper version (and language?).
Added subscriber: @dr.sybren
In that case I would vote for changing the key to
documentation_url
. It can point to the wiki or the manual, or anywhere else. Naming something 'wiki' but allowing it to have non-wiki values, that looks confusing to me.I like the idea, but this is very close to Python's
f""
notation. Maybe"$BLENDER_MANUAL_URL/addons/import_export/scene_gltf2.html"
? Or${BLENDER_MANUAL_URL}
if you want it to be more 'enclosed'.That's all fine with me, the precise naming and syntax I'll leave up to Python and Add-on project maintainers. If we want to rename
wiki_url
, it can be done in a way that's backwards compatible.Mainly I wanted to suggest that constructing the URL should be done by Blender, so that we can more easily change it if we need to later. For example to support taking into account the language, or using downloaded docs rather than a website.
Added subscriber: @Tobias
This comment was removed by @Tobias
@Tobias can you better explain that, you have a double negative and I am not exactly sure what part of this task you are responding to.
never mind, I overlooked that you have edited the script.
This has been updated in blender/blender@a0ea0153c2 I will update all the addon URLs.
@Blendify Is that something that will be added in 2.82a ?
No, it is not a big deal. Will be a part of 2.83
My understanding is that the links in 2.82 work now due to redirects, but they will point to the latest version of the docs rather tham the 2.82 version specifically.
If so, I agree that's not something critical to fix for 2.82a.
Sorry, I thought the redirection was not effective, but seems it was my browser cache that was not updated
So, I agree this is not critical too, redirection will do the job until 2.83
