UI: Metadata Panel is added to every Sidebar Tab #74041
Reference: blender/blender#74041
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 600 Intel 4.5.0 - Build 26.20.100.7262
Broken: version: 2.83 (sub 4), branch: master (modified), commit date: 2020-02-18 11:23, hash:
e3e6dc41a7
The empty Metadata Panel is added to every Sidebar tab here and there, all over Blender. Ex. in the Sequencer Preview:
Added subscriber: @tintwotin
#86969 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Can confirm.
This is where the metadata panel shows up:
Footage
tabImage
tabStrip
tab?)Also checking why it is always empty apparently...
Or put it in its own "Metadata" tab?
sequencer_ibuf_get
will still get me a PNG? Still needs more investigation...Added subscribers: @iss, @Sergey
OK, I am not sure how this would ever work in the Video Sequencer if we try to get the ImBuf from
sequencer_ibuf_get
(as this gets rendered and there is no metadata on the newly rendered ImBuf)...@Sergey, @iss : am I missing something? If this indeed cannot work (by design), should we instead change direction and put the metadata panel as part of the strip tab (getting the metadata for the strip instead -- which should work, would be happy to write a patch for this)
regarding the issue of the panel being everywhere: it just needs a category (being it its own "Metadata" or alternatively put in the "Strip" tab - see above)
P1269: T74041_snippet
relevant commits:
8c87af7440
(put the panel in "Footage" for MCE, had it in all tabs for Image Editor & VSE)83d78eb32c
4d89667663
340c564020
(moved the panel to the Image tab for the Image Editor)It should only be in the Sequencer Preview Sidebar Tab called View - as it is only printing data in the preview and is executed when the playhead moves. AFAIR it only works for Blender generated EXR files, saved with that meta data inserted. There was the same problem in the Sequencer/timeline sidebar and it was fixed by Sebastian(?), but I can't find the commit.
Nb. it is also inserted into tabs generated by add-ons. The Misc tab above in the gif - is from an add-on.
"View" could be good, yes (if it would really work to get the metadata from the preview...)
Cannot get it to work. What could I be doing wrong?
That should go away if we give it a category
Changed status from 'Archived' to: 'Confirmed'
I am reopening this, since the same has been reported again in #86969 (UI: Metadata option is added in all VSE Preview Sidebar tabs) (and I am not sure why this was closed at that time, this report already has a bit more information...)
This seems to be resolved everywhere else, will look into limiting appearence in VSE.
This is bug - metadata should be transfered to final
ImBuf
.This data could exist per strip too, which arguably could be better solution.
This sounds reasonable, committed in
3400ba329e
.Forgot to mention task in commit, so closing now.
Just a note, that metadata are copied only when only one strip is being processed, so when you blend 2 strips, they are not. I can see this in some effects, and it would be probaly easier and cleaner to support metadata on strip level than constantly make sure that you don't miss
IMB_metadata_copy
somewhere.Edit: But on other metadata panel for each strip wouldn' be great either, because you will have to first click on correct strip first to see anything and this can be problem when you want to see metadata but strips are too small.
Alternative could be to iterate through "temp cache" items that are guaranteed to contain all images produced by all strips, and print all metadata per strip. But this could too get messy in complicated edits.
