Blender crashes on Render #74188
Reference: blender/blender#74188
Operating system: Win 10
Graphics card: Nvidia GeForce GTX 670MX
Broken: 2.8.1a
Based on attached File:
HDD Red.blend
Added subscriber: @DirkSchiller
Added subscriber: @ankitm
the memory keeps increasing after some time, while CPU remains low. Happens only in EEVEE, not in cycles. tested with 2.83
f61f26b033fd
T74188log.txtAdded subscriber: @EAW
Thank you for the report.
You have quite a few settings set at maximum values.
For example, this musgrave node has it's detail set to 16 (the max), in addition to the dimensions at 61 and Lacunarity at 50.
I duplicated it and set detail to 1, the other 2 values to 0. I then subtracted the two to show you the visual difference, which would show up as white. As you can see, the surface is completely black because there isn't any. However, your computer is calculating an incredible amount of data to create that additional noise that we can’t see. You should lower those values.
You have many bevel modifiers with 100 segments, and nothing is smooth shaded. Reduce the amount of segments, and use smooth shading with auto smooth on.
The number one reason I think this crashes for you is that you have set the depth of field F stop to its maximum value of 0.1. That is one of the most memory intensive things you can do.
It appears this crashes because Blender ran out of memory.
While we want to improve Blender to handle such cases memory gracefully, this is not currently considered a bug.
Thank you Evan! I will consider your Tips! I understand that it is important to improve Values and Properties accordingly to avoid Memory Peaks.
Is there a way to indicate High Processing / Memory Usage inside Blender ? Eg. a Value has some Kind of Mark to indicate possible Memory Issues or Nodes display Warnings on to fancy Values ?
It would be hard to pre-emptively calculate the required resources, particularly memory. Though keeping unnecessary details out of trial projects is a good idea. Later you can decide if something needs to be bumped up.
Thanks to Evan's Tips I could reduce the Faces from 290k to 50k by changing the Bevel Segments and using Shade Smooth with Auto Smooth and sometimes with Weighted Normal Modifier.
