'Join' does not preserve face orientation for negative scales #74237
6 Participants
Reference: blender/blender#74237
Graphics card: Quadro RTX 3000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.22
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
f1aa4d18d4
Short description of errorjoin_face_orientation_problem.blend
When joining multiple meshes, if some of them have a negative scale (mirror), the joined mesh has flipped faces, while the original display in viewport was good (with backface culling enabled)
Note that the faces may be flipped on mesh parts that had no negative scale, it seems to depend on the active object.
May be similar to #57612
Ctrl-J
to join the two preselected cubesAdded subscriber: @rotoglup
#88164 was marked as duplicate of this issue
#78508 was marked as duplicate of this issue
FWIW I'm able to workaround this using some scripting :
Added subscriber: @mano-wii
Join is a simple operator. And it doesn't check, nor flip the faces when the matrix is negative.
I don't see this as a bug, the faces are flipped, but the renderers make up for it by checking the matrix.
What if an external renderer does not make this adjustment?
What if a modifier is counting on the current face orientation in a file?
If this change was in favor of a python script, I think this adjustment should be done in the script.
Hi, I see you changed the status to 'Needs Information from User', I'd be happy to, but I'm not sure what more information I could provide ?
I see the current behaviour of
join
as problematic because I can't detect or prevent face flips before joining, without coding a script :For a negative-scaled object :
As there is no warning either, the
join
operation may provoke had-to-detect (and hard-to-recover later) flips.Being new to Blender, I can't really answer those questions.
As a developper, I'm not aware of a sensible use case where flips are not 'compensated' after negative scales, which happen a lot after mirrors & co.
Ok, marking it as know issue, since the priority is low and there are no plans to fix it soon.
Added subscriber: @ideasman42
Closing, since this is working as expected.
Flipping faces on join could be an option, though.
Added subscribers: @bblanimation, @iss
I don’t understand the latest comment from @ideasman42; how is it the expected behavior that a face normal would flip when joined with another object? It's a very unintuitive behavior that seems problematic to me from a usability standpoint.
Added subscribers: @ZachHixson, @kioku, @filedescriptor
@bblanimation logically - an odd number of negative scale causes the face direction to flip.
Blender detects this and corrects for it when drawing.
When joining though, there is no logic in Blender to correct for this per-face, so the faces show as flipped.
Reversing the direction of a face can be done but it's a destructive modification to the mesh, while it's probably fine in most cases, features that depend on vertex order in the face would behave differently. Instancing geometry on faces for example.
We could accept this behavior (or have an option) I'm just noting that this is currently working as intended, and there are potential down-sides to flipping faces for the user.
I submitted the duplicate of this a few days ago, having failed to find this. I thought it strange no one else had encountered it.
But how is this not a bug?
Someone says "Blender detects this and corrects for it when drawing" but that is just hiding the problem. The reversed faces are still there, and if you try to 3d print the model, it will have holes in it. I know, because I did that. The fact that Blender hides that is, frankly, worse than if it did not.
