Problem in display wireframe while xray and Viewport Anti-Aliasing activated
Confirmed, HighPublicBUG
Operating system: Linux-5.3.0-40-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.83 (sub 5), branch: master, commit date: 2020-02-26 13:59, hash: rBfe41c1ec0b79
Worked: 2.82a
Glitches in viewport in wireframe mode
  • Subdivide default cube with 100 cuts
  • Return to object mode
  • Deselect the cube
  • Activate X-Ray (more than zero) and Activate Viewport Anti-Aliasing (5 Samples or more)
If you don't see the problem toggle shading between solid and wire
The problem disappear when Viewport Anti-Aliasing set to No or Single Anti-Aliasing
For a heavier file check 01.anim.blend from the dweebs and go on wireframe mode.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Feb 27 2020, 4:05 PM
I don't know what to look for. I don't see any problem:
to see the artifacts you need to : first back to Object Mode then deselect the model .
the artifact gone when selecting any object . if the artifact disappear toggle shading mod between solid and wire.
this cube is subdivided with 100 cuts and
I still can't reproduce the problem.
But by the image, there is really something strange there.
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Mar 2 2020, 10:42 AM
Operating system: Linux-5.3.0-7629-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
Broken: version: 2.83 (sub 7), branch: master, commit date: 2020-03-10 12:30, hash: rB212660f46745
can confirm
build: 2020-03-11, hash: 33c6b269d116 ,windows 10
xray 0- 0.99
xray value 1 solves the problem
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Needs Developer to Reproduce.Thu, Mar 12, 12:46 AM
Dalai Felinto (dfelinto) changed the task status from Needs Developer to Reproduce to Confirmed.Fri, Mar 13, 6:45 PM
I will keep this opens since the sample file is simpler.
Dalai Felinto (dfelinto) renamed this task from Problem in desplay wireframe while xray and Viewport Anti-Aliasing activated to Problem in display wireframe while xray and Viewport Anti-Aliasing activated.Fri, Mar 13, 6:48 PM
Dalai Felinto (dfelinto) triaged this task as High priority.
Dalai Felinto (dfelinto) updated the task description. (Show Details)
Julian Mohr (Jules) added a comment.EditedFri, Mar 13, 9:20 PM
Played with a heavier file and it seems to only affect occluded faces or something with depth.
Also changing wireframe in Viewport doesent change anything only Xray value 1 in Viewport Shading solves it.
Or if you set your user prefs Viewport Anti-aliasing to no Aliasing
(probably workbench refractor releated?)
Edit: it seems also to affect not occluded faces far away from viewport as you can see here:
Brecht Van Lommel (brecht) changed the task status from Confirmed to Needs Information from User.Mon, Mar 30, 8:48 PM
This looks similar to T75063 which appears to be fixed now, can anyone confirm?
With the last branch it is More better , but the problem still with heavy scenes . to see the problem in a default cube : make a duplicate the subdivide it 100 cuts
Brecht Van Lommel (brecht) changed the task status from Needs Information from User to Confirmed.Tue, Mar 31, 10:17 PM
