Blender 2.82a proposed revisions
Closed, ResolvedPublicTO DO
Blender
Add-ons
Related Objects
Mentioned In
D6821: Fix T73369: Corner Pin widget is unreasonably large
Mentioned Here
T74425: Can't texture paint an images sequence anymore
rBca717f0489af: Fix T74425: Cannot texture paint an images sequence anymore
rB212660f46745: Fix T73369: corner pin & sun-beam nodes gizmos are too big
T63892: Tools cannot be registered into some contexts (e.g. PAINT_TEXTURE).
T72028: Crash switching to vertex paint (from editmode, mesh with modifier, after adding/removing geometry in editmode)
T74225: Image sequence for texture wont work
rBd95e9c7cf80a: Fix T63892: Tools cannot be registered into some contexts (e.g. PAINT_TEXTURE)
rB9dbfc7ca8bf4: Fix T74225: Image (from sequence) cannot be loaded
rBf38c54d56ef5: Fix Vertex weight gradient tool show wrong weight/strength values in the UI
rBee7034949fd8: Fix bone envelopes displaying wrong when armature is scaled
rB31aefdeec5a6: Fix T72028: Crash switching to vertex paint
rBa200986273de: Keymap: Add front/back Alt-MMB absolute view axis switching
rB2df040ed58fb: Fix T54270: Reset last_hit and last_location when reading the file
rB32fc22db5679: Fix T72253: Mantaflow adaptive domain cuts off
rBe5f98c79b0ed: Fix T74431: EEVEE AO Render Pass
T73932: Showstopper: 2nd keyframe for image sequences can't be set in compositing
rBab18dbb67e05: Fix potential crash with Eevee render of missing image textures
rBed8aa154a33d: Fix crash loading .blend file saved with Blender 2.25
rBf0a22f5dd085: Fix T73932: modifying keyframes in nodes fails when there is an image sequence
rBf881162f81e5: Revert "Constraints: remove special meaning of Local Space for parentless…
T74092: "ReferenceError: StructRNA of type Mesh has been removed" when accessing mesh data (created using depsgraph evaluation) after rendering by script
rBA569f96c037e5: glTF exporter: perf improvement in texture export
rBA659c121a6812: glTF exporter: fix some strange reference error in blender api when exporting…
rBAaf687f5a041e: glTF exporter: avoid crash using compositor rendering for image generation
rB360443a48346: Fix T74278: Light, Image Object, and Compositor Backdrop Viewer Node gizmos are…
rB498397f7bd81: Fix (unreported) Separate bones creates empty armature
T74295: Cloth + Internal springs crashes on a non-polygonal geometry
rB1648a7903672: Fix T74295: Cloth + Internal springs crashes on a non-polygonal geometry
rB9c4523b1fde4: Fix crash when compiling renderpass shader on some AMD drivers
T54270: Assert failure in brush projection code
T72903: Bone Envelope and Bone Size tools appear to have switched functions
T73862: Can't save file because of too many open files
T73898: 2.82 crash when changing image from tiled to single
T74003: Autocomplete bug with mesh.loop_triangles. in Blender Python Consolle
T74182: Blender crashes by saving a painted texture in properties/texture properties
rBd6977b538791: Fix T73898: UDIM crash changing form tiled to single
rB60890ccf9d33: Fix T73862: Fluid Sim file handle resource leak
rB69c587888b5e: Fix T74003: Autocomplete bug with mesh.loop_triangles. in Blender Python…
rB096936fe1d42: Fix T74182: Crash saving images from non-image spaces
rBdd2cdd436f8c: Fix T72903: Bone envelope & bone size tool functionality swapped
rB9cac5fa681c5: Fix camera border gizmo size
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.Feb 28 2020, 3:32 AM
Dalai Felinto (dfelinto) changed the subtype of this task from "Report" to "To Do".Feb 28 2020, 10:28 AM
My proposal is to do the 2.82a once we switch to bcon2, so in March 12. I will present that to the next developers meeting.
I would also like to propose to re-enable building of the 2.82 branch on the buildbot and changing its version to "2.82a beta" (or "2.82 stable").
This way we can get some testing before the release and verify all the tests pass as we backport commits.
I'd like to propose to add rBAaf687f5a041eeda7bbe853a5839c2d57223134b2 to 2.82a
This is a fix for a regression between 2.81 and 2.82 in glTF exporter( that leads to a crash) introduced during a performance improvement (commit rBA569f96c037e5dfefd9e1127dca4de92746d99c31).
Note that technically, rBAaf687f5a041eeda7bbe853a5839c2d57223134b2 (that I propose to add to 2.82a) removes a workaround added in rBA659c121a6812175e5d3fa67f93c230fdad540ff3, and add a proper fix. So maybe both commit will be needed to avoid merging issue.
Side node: The root cause is maybe a depsgraph issue, logged here: T74092
Intermediate status update. Commits mentioned up until my claiming of the task have been picked and pushed to blender-v2.82-release
2.82a has been released.
