Weight- Vertex- and Texture Painting circle halts when moving under menu. #74398
Closed
opened 2020-03-03 14:25:31 +01:00 by Jonas Törnros · 11 comments
Graphics card: Quadro 2000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 377.83
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: 77d23b0bd7
  1. Switch on both 3d-viewport menus using (T) and (N).
  2. Enter either Weight- Vertex- or Texture Painting mode.
  3. Move the cursor over the cube and out to either right or left under the menus and notice how the cursor comes to a halt, visually.
  4. It is still possible to paint, it just visually seems to stop when cursor is crossing the menu vertically.
#74398.blend
Best regards,
Jonas
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: Quadro 2000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 377.83 **Blender Version** Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: `77d23b0bd7` Worked: (optional) **Short description of error** Weight- Vertex- and Texture Painting circle halts when moving under menu. **Exact steps for others to reproduce the error** 1. Switch on both 3d-viewport menus using (T) and (N). 2. Enter either Weight- Vertex- or Texture Painting mode. 3. Move the cursor over the cube and out to either right or left under the menus and notice how the cursor comes to a halt, visually. 4. It is still possible to paint, it just visually seems to stop when cursor is crossing the menu vertically. [#74398.blend](https://archive.blender.org/developer/F8387172/T74398.blend) Best regards, Jonas
Author
Added subscriber: @Pewi
#74444 was marked as duplicate of this issue
Added subscriber: @Asad-ullahKhan
Ahh I see. It should be added that this does not happen if you are pressing and holding the left mouse button. If I might suggest a slightly more expressive blend file (I have attached it)
T74398_new.blend
Ahh I see. It should be added that this does not happen if you are pressing and holding the left mouse button. If I might suggest a slightly more expressive blend file (I have attached it) [T74398_new.blend](https://archive.blender.org/developer/F8387511/T74398_new.blend)
Member
Added subscriber: @pm
Member
Member
Thanks for the report. The issue is that the panels "region" overlapping the 3D view actually overlaps for the full vertical height, so the code that draws the brush circle probably thinks it's in a panels region rather than the 3D view.
I think this should be classified as a bug. The overlapping regions shouldn't be causing problems like this.
Here's a quick example.
Screencast from 09-08-2020 12:26:59 PM.webm
Thanks for the report. The issue is that the panels "region" overlapping the 3D view actually overlaps for the full vertical height, so the code that draws the brush circle probably thinks it's in a panels region rather than the 3D view. I think this should be classified as a bug. The overlapping regions shouldn't be causing problems like this. Here's a quick example. [Screencast from 09-08-2020 12:26:59 PM.webm](https://archive.blender.org/developer/F8855035/Screencast_from_09-08-2020_12_26_59_PM.webm)
Member
Added subscriber: @lichtwerk
Member
This looks like a duplicate of #79937 (Brush cursor (sculpt, vertexpaint, weightpaint) stuck/doesn't draw under transparent part of N-panel).
Since the other report has a bit more information, will merge this report into #79937
This looks like a duplicate of #79937 (Brush cursor (sculpt, vertexpaint, weightpaint) stuck/doesn't draw under transparent part of N-panel). Since the other report has a bit more information, will merge this report into #79937
Member
Closed as duplicate of #79937
7 Participants
Reference: blender/blender#74398
