CUDA 10.2 and GTX 1080 render artifacts with path tracing
Confirmed, NormalPublicBUG
Operating system: Linux-5.3.0-7629-generic-x86_64-with-Ubuntu-19.10-eoan 64 Bits
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-04 04:24, hash: rBfb330dd11098
Worked: 2-3 days ago
One of the recent changes to Cycles has introduced a Path Tracing sampling error when using CUDA on a 1080.
It does not happen with an RTX 2080, and also not when using OptiX. It also does not occur when using BPT.
Open this file and render.
Brecht Van Lommel (brecht) changed the task status from Needs Triage to Needs Information from User.Thu, Mar 5, 11:29 AM
I can't reproduce this with the rB3da2dc82132f build from builder.blender.org/download/, using Quadro RTX 5000.
I can't find a buildbot build with revision rBfb330dd11098, is this a custom build?
Can not reproduce with blender-2.83-31aefdeec5a6 build from yesterday.
Windows 10 Pro
Geforce 1080 Ti
Geforce GTX Titan X
Driver: 440.97
Hm, that's weird. I just did a fresh build (cd0a6ff5c453), and still have the issue. I have 3 cards, two 1080 and one 2080. I can test with both GTX cards and the issue is always there, just not with the RTX. I also have no patches or so applied.
Can you test with the buildbot build, so we know if the difference is in the build or the hardware/drivers?
Might indeed be the 10.2 toolkit, as @Steffen Dünner (SteffenD) mentioned in the other report. I just tried with buildbot and that one renders without issues.
Does not reproduce for me either with RTX Q4000, CUDA V10.2.89, gcc version 7.4.0, Nvidia drivers 440.33.01.
It's probably not CUDA 10.2 itself but something else.
@Sebastian Koenig (sebastian_k) since you're making your own builds, do you have the time to git bisect the commit that introduced the bug?
Brecht Van Lommel (brecht) changed the task status from Needs Information from User to Needs Developer to Reproduce.Thu, Mar 5, 2:48 PM
It's not unusual for new CUDA toolkit versions to give us bugs like this, and us having to fix or work around it. Sometimes it's a bug in Cycles, sometimes it's a bug in CUDA.
git bisect may reveal the issue, but to me it seems unlikely to have been a recent commit.
Brecht Van Lommel (brecht) renamed this task from CUDA sampling bug with Path Tracing to CUDA 10.2 and GTX 1080 render artifacts with path tracing.Thu, Mar 5, 2:49 PM
It looks like this is the solution. In my case removing CUDA 10.2 and installing 10.1 got rid of the artefacts.
If 10.1 does get rid of the error, than I also think it is not a recent commit. I did install 10.2 recently, shortly before @Stefan Werner (swerner) committed the progressive multi-jitter. If thought it was because of that, but yeah, it seems more likely that the new cuda toolkit is indeed the culprit.
I plugged in my GTX 1080Ti and git blame points to the commit that brought the PMJ sampler:
https://developer.blender.org/rB409074aae56138f49ce078ce919a6d02e44e521e
It reproduces with the scene attached to this bug, regardless of the sampling pattern that is selected.
Stefan Werner (swerner) changed the task status from Needs Developer to Reproduce to Confirmed.Thu, Mar 5, 4:39 PM
Hmmm... I can not reproduce this error on Linux Mint 19.3 with a GTX 1080Ti.
Both the current buildbot build and my own build (with CUDA 10.1) render properly:
I reported a bug with adaptive sampling before, but that was simply because I compiled using CUDA 10.2
Using CUDA 10.1 fixed the adaptive sampling, what version of CUDA are you building with?
CUDA 10.2 + PMJ commit shows the render error. CUDA 10.2 and any revision before the PMJ commit renders fine.
Reproduces with 1080Ti/CUDA 10.2 on Windows as well.
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Bug".Mon, Mar 9, 5:36 PM
@Stefan Werner (swerner) is this something you plan to fix? I don't see anything obviously wrong in the code, so I guess it's a commenting out code until the cause is found.
If it helps and this is caused by a compiler bug, we could also consider removing CMJ sampling.
