No render in VP9 lossless mode #74443
6 Participants
Reference: blender/blender#74443
I wanted to export a video with
Image:
I thought it might be the 4K size or the other setting, but it seems that blender does not like the lossless since perceptually lossless with the same setting works as expected. I also check it with cycles, since my GPU is rather old. Cycles is the same problem.
Blender file
VP9 no lossless.blend
You don't even have to use the video editor. blender seems to have the same problem in the dafault 3D view when you press Ctrl + F12
Added subscriber: @forceengine
Added subscriber: @ankitm
Please share a simple blend file with external resources if any that helps redoing the bug
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
I wondered if VP9 really has a lossless mode. Wikipedia says "VP9 is customized for video resolutions greater than 1080p (such as UHD) and also enables lossless compression."
ffmpeg.org says "libvpx-vp9*has a lossless encoding mode// that can be activated using -lossless 1"
Lossless code:
or
I have no idea, but could it be that simple that the lossless mode tries to pass arguments using one of the CQ-ways. This would explain why it can not work.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
This issue was referenced by
98689f51c0
Added subscriber: @lichtwerk
Not exactly sure if we should use
lossless
mode, but rendering should definitely not fail.Changed status from 'Confirmed' to: 'Resolved'
