Generative modifiers supporting vertexgroups [solidify, wireframe, ...] still act on vertices ouside the vertexgroup (zero weight just acts as a factor) #74452
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
6 Participants
Reference: blender/blender-manual#74452
Operating system: Darwin-15.6.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris Pro OpenGL Engine Intel Inc. 4.1 INTEL-10.14.74
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash:
blender/blender@26bd5ebd42
when a solidify is add and use you vertexgroups, it looks like none targeted faces still get solidify effect. It looks like its simply adjusting the thickness according to the vertexgroups. It still influences the none targeted mesh. The tiptool does state it indeed, prehaps im wrong. I thought the vertexgroups managed if it was added yes or no
01 Open attached model
02 Go into edit mode and see the grip (thin part) has normals pointing 2 directions
2-solidify-issue.blend
Added subscriber: @RomboutVersluijs
blender/blender#88118 was marked as duplicate of this issue
blender/blender#87074 was marked as duplicate of this issue
blender/blender-addons#74456 was marked as duplicate of this issue
In addition to this, the manual does state only vertex groups get the applied effect. I also check 2.79 and it showed same behavior
https://docs.blender.org/manual/en/2.82/modeling/modifiers/generate/solidify.html#bpy-types-solidifymodifier
It looks like vertices outside the group also get solidified but get a thickness of zero. This results in Z-fighting or double vertices
Edit
But a bit down when we check the factor, it already states 0 creates double vertices. BUt that kind of contradicts what is said earlier about using vertexgroups.
Added subscribers: @Gilberto.R, @lichtwerk
Added subscribers: @howardt, @mont29, @ideasman42
Afaict, this is true for all generative modifiers supporting vertex groups.
Participating vertices are not filtered by their vertexgroup prior to applying/executing the modifier.
Dont really think this is a bug, it is more of a design question (it sure would be nice to support this though -- might be quite some work to get this straight for those modifiers).
Would kindly ask for advice here on how to classify this report (will tag as a design question for the time being)
CC @ideasman42
CC @mont29
CC @howardt
solidify adds faces to non-targeted meshesto Generative modifiers supporting vertexgroups [solidify, wireframe, ...] still act on vertices ouside the vertexgroup (zero weight just acts as a factor)Changed status from 'Confirmed' to: 'Archived'
This is indeed working as expected, no bug here. Thanks for the suggestion, fully ignoring zero-weighted geometry would be a nice new feature, but we do not keep track of feature requests on this tracker.
So i need to go to rightclickselect i guess, right
Never actually knew is actually generates faulty meshes. Intersecting vertices is never good.
PS shouldnt the manual be more clear, now it contracts itself when you check factor vs vertexgroup part
The current behavior is counterintuitive and limits non-destructive workflow. Users would'nt ever expect that behavior, so I think it should be a known issue, even if it's a design choice. At least the manual should be updated to make this behavior more clear to the user. I hope this can be worked on in the future.
Added subscriber: @KonstantinsVisnevskis
Added subscriber: @Blendify
Since this has come up again, I will point out that documentation (only checked
Solidify
) is borderline misleading here:https://docs.blender.org/manual/en/dev/modeling/modifiers/generate/solidify.html
This is actually wrong I think, modifier acts on all vertices, it is just the thickness that is affected.
Raising awareness to @Blendify here.
Added subscriber: @jordanp.lawson
Changed status from 'Archived' to: 'Confirmed'
Indeed, that was something I was trying to explain as well. The manual kinda contradicts itself in the explanation. I guess a more clear description would be nice and perhaps a tip of using a weld modifier to solve possible issue when double vertes or the zero can be fixed that way
Fixed in rBM8326 and rBM8335
