Ungrouping destroys NodeCustomGroups
Confirmed, NormalPublicBUG
Operating system: Linux-5.0.0-38-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GT 730/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.56
Broken: version: 2.83 (sub 6), branch: master, commit date: 2020-03-05 21:23, hash: rBeed1beff88af
When a group is ungrouped, user counters are not incremented for contained customgroups.
After deleting a copy of such nodes (eiter in outer tree or remaining in group) the other copy is left with 0-counted node tree and eventually get damaged
  1. load attached file and allow executing embedded script -- the script will registed a CompositorNodeCustomGroup with dumb nodetree and sockets for more dramatic effect
  2. call operator 'add test node' and add the node to compositor
  3. group the node
  4. duplicate the group
  5. ungroup one of the groups
  6. check data view -- 'foo.tree' should have 2 users (the remaining group and compositor nodetree), but it has only 1
Revisions and Commits
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Thu, Mar 12, 1:53 PM
I didn't understand what you meant in the point 7. "open another group and delete node 'foo' there".
Is there really a need for custom nodes and script execution?
It is good to simplify a report to the minimum steps to save time either in the reproduction of the bug or in the investigation.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
NodeCustomGroup is needed because it contains reference to NodeTree which should be usercounted.
However, I've just tested, the similar happens with ImageTexture which also reference to an ID, but via property.
Minimal steps would be just 1-6 that result in improper user counter, but they do not result in any destructive effects.
Germano Cavalcante (mano-wii) changed the task status from Needs Information from User to Confirmed.Thu, Mar 12, 6:28 PM
This case seems resolved in D6484
Snippet:
source/blender/editors/space_node/node_group.c:193-203
This also affects ordinary nested groups.
  1. greate a node
  2. group it and name the group 'inner'
  3. group the group again into 'outer' group
  4. duplicate outer group
  5. ungroup outer group
  6. inner group nodetree now has 1 users counter instead of 2
  7. (deleting either copy of inner group will leave remaining copy with 0 users)
  8. (reloading file or cleaning orphans will destroy content of the inner group)
Should the cases with image texture and nested group be reported as separate bugs?
Apparently, this bug used to be compensated by another bug, adressed in rBe993667a46c2
Before that fix, ungrouping operation resulted in double-increased user counters.
In the reported scenarios, stuff from froup got 3 users instead of 2. This helped to avoid destructive effects.
(I checked it for customgroup, nested groups and image texture)
