Grease Pencil 2.82 version file crashing Blender 2.83
Closed, DuplicatePublicBUG
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.83 (sub 8), branch: master, commit date: 2020-03-11 19:45, hash: rBe6d0a438ab95
Grease Pencil 2.82 version file with Blur Fx is crashing Blender 2.83 while loading. I tested it with the Grease Pencil Branch, and it is also the same problem there.
In the properties panel, try to slide the focus_blur parameters. Not all of them cause crash though.
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Needs Information from User.Thu, Mar 12, 10:22 AM
I cannot reproduce it.
Could you provide me a 2.82 test file with the crash?
2.82a seems to have fixed part of the problem. The steps listed in the original message doesn't seem to cause a crash. However the problem persists with older files created in 2.82.
This file (uploaded) was originally created in 2.82. After I saved it again from 2.82a, it seems to open fine in 2.83. But as soon as I try to tweak the Blur (Renamed to "Focus_Blur") parameters it crashes.
Ankit (ankitm) renamed this task from Grease Pencil 2.82 version file with Blur Fx is crashing Blender 2.83 while loading to Grease Pencil 2.82 version file with Blur Fx is crashing Blender 2.83 on changing the blur parameters .Wed, Mar 18, 9:07 PM
Ankit (ankitm) changed the task status from Needs Information from User to Confirmed.
Ankit (ankitm) updated the task description. (Show Details)
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Bug".Thu, Mar 26, 12:05 PM
The problem is not limited to Blur Fx apparently. Trying to scrub the values on Rim Fx also causes a CRASH.
I narrowed the problem down to Fill Shapes (any area filled with the "Fill Bucket Tool"). Fill shapes seems to be unstable and causing random crashes. In the same file I originally uploaded (B28_GP_TwoGuysYelling2.blend), if you delete the fill shape ("Mat" material) crashes seems to disappear. Although, there is still a flicker when scrubbing the values on either Fx parameter.
Thank you very much for all the great work!!!!
Antonio Vazquez (antoniov) renamed this task from Grease Pencil 2.82 version file with Blur Fx is crashing Blender 2.83 on changing the blur parameters to Grease Pencil 2.82 version file crashing Blender 2.83.EditedSat, Mar 28, 11:51 AM
The problem is more general opening 2.82 files, not related to Blur only or VFX. We are looking to try to find the bug.
I am also getting crashes when using Fill Bucket tool within a 2.83 project.
