Incorrect mixing in Glare node #74680
6 Participants
Reference: blender/blender#74680
Operating system: Windows-10-10.0.16299-SP0 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.83 (sub 8), branch: master, commit date: 2020-03-12 00:33, hash:
8751af6d19
Worked: Never (2.79+)
Glare node with mix between -1 and 0 will brighten entire image
See attached file:
glare_bug.blend
First set Mix value to 1 and render to see only effect
Setting Mix to 0 is supposed to give a middle point between original and processed image. You can see that the background is not brightened:
Render image.
Mix set to -1 essentially disables glare. The background is also not brightened:
Render image.
Set Mix is set to -0.5
Render image. You can see that glare brightened entire image - this should not happen
Added subscriber: @MarcinTwarowski
Added subscriber: @mano-wii
I don't understand what the issue is here.
The mix is between -1 and 1.
The images you showed show what Glare is intended to do.
source
At Mix -0.5, the background is brightened, when only the emmisive part should be. Quickly switch between first two images. At mix = 0 it does not happen.
Added subscriber: @iss
I can confirm this
If you render with mix of 1, you will see, that no brightening near image edges should happen here
Glare node brightens entire image when mix is between -1 and 0to Incorrect mixing in Glare nodeAdded subscriber: @szulat
This issue was referenced by
95e010a22e
