Render cloth animation does not resets cache
Confirmed, NormalPublicBUG
Broken: 2.82.7
Worked: 2.79b
When modifier Subdivision is before the cloth physics modifier,but with different subdivision settings for rendering and viewport, the cache remains active even when rendering.
Possibly related to T74523.
  • Open attached file
  • Run animation (without baking)
  • Render animation
Notice that the cloth is deformed with each rendered frame.
This is because rendering reuses the cache.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Fri, Mar 13, 7:58 PM
Evan Wilson (EAW) closed this task as Invalid.Fri, Mar 13, 8:14 PM
Evan Wilson (EAW) claimed this task.
Thank you for the report. This is noted in the manual under the cache settings under cloth simulations.
https://docs.blender.org/manual/en/dev/physics/cloth/settings/cache.html
Evan Wilson (EAW) reopened this task as Confirmed.Fri, Mar 13, 8:16 PM
While getting the manual page and checking other similar reports, I see @Germano Cavalcante (mano-wii) already triaged this, so I will set it back to his status and subtype.
Germano Cavalcante (mano-wii) changed the subtype of this task from "Bug" to "Known Issue".Fri, Mar 13, 8:28 PM
I actually edited the description and added the "bake" information.
But the problem with the cache after bake seems to be a known issue.
The original report seemed to be more of a problem with the cache not being reset when rendering the animation.
I will test and re-edit the description.
Germano Cavalcante (mano-wii) renamed this task from Render displays cloth with Subdivision unnormal to Render cloth animation does not resets cache.Fri, Mar 13, 8:38 PM
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
Germano Cavalcante (mano-wii) changed the subtype of this task from "Known Issue" to "Bug".
Evan Wilson (EAW) removed Evan Wilson (EAW) as the assignee of this task.Sat, Mar 14, 2:39 AM
