Video Editing: Preview shows previously cached frame after Hard Cut and Extend #74875
Reference: blender/blender#74875
Operating system: Win 10, 64bit
Graphics card: no
Broken: (v 2.82a) and also (v 2.83 Alpha, Date 2020-03-18 17:16, Hash
c9c08dc7c8
)Short description of error
I often freeze a sequence, by hard cut, move the right part and extend the left part.
(1234) -> hard cut -> (12|34) -> move right -> (12|--|34) -> extend left -> (1222|34)
Sometimes the preview then shows a previously cached frame at the beginning of the frozen sequence, resulting in a visible backward motion.
Correct Preview: (1222|34)
Wrong Preview: (1232|34)
In the Video Editor:
Step 0: Add a scene or image sequence with 4 frames (1234) or open the attached file bug test.blend.
Note 1: Error MAY NOT occur, if during Step 1, the left arrow key < was pressed.
Note 2: Error MAY NOT occur, if during Step 1, the Play Animation button was pressed.
Note 3: Error DOES occur, if in Step 1, the mouse is used to reach Frame 3 (as far as I have tested it)
Note 4: Error DOES NOT occur, if the time cursor is moved between Step 2 and Step 3.
Note 5: Error DOES occur, if the initial scene has a different number of frames.
Note 6: Error DOES occur, if the Hard Cut is at a different position.
Note 7: Error DOES NOT show in the rendered animation
Note 8: I think, in one case, there were multiple incorrect frames, like a flicker (1234) -> (12323232|34) instead of -> (12222222|34), however, I could not reproduce.
Picture 1: Correct Preview
Picture 2: Wrong Preview
Added subscriber: @gabi2002
Added subscriber: @iss
I had one similar report to this, I think this bug made it to final render. I wasn't able to reproduce though. I will look at code and see if there is some type conversion or anything, that could caused this, but reproducible case would help a lot.. Can you tell at what framerate did this happen?
95% sure, it was 24fps for both scenes (video editor and animation source).
Please don't waste too much time on Note 8. I was wildly experimenting with scripts and render settings that also caused all sorts of flickers. So, I'm only 50% sure, that the Note 8 flicker was caused by a hard cut.
I suggest, find the reproducible bug, and then consider for 10 minutes, if the reproducible bug might also cause some kind of flicker.
Do you have a report number of this similar report? Maybe it helps me to trace my steps back.
Best
Gabriel
Sure.
#72683 (Blender VSE 2.8 speed control doesn't match render)
If it's same issue it would probably be linked to speed control and possibly only when it is used to stop or pause input strip, but technically it could happen even after hard cut
I retraced the error steps of #72683.
Adding the speed effect made my bug worse.
However it only affects the preview. Rendered frames are fine. So, I couldn't reproduce the problem reported in #72683.
To ease reproducing, I left Multiply Speed set to 1 (no change)
Soft cut, add speed effect
Soft cut, move cursor, add speed effect
This third version of my bug is similar, to what I remembered in Note 8. However, Note 8 did not involve a speed effect.
stretch speed controlled strip
Best
Gabriel
This issue was referenced by
bbf1c83370
@iss thank you so much for the fix #74875! What a beautiful Easter gift :)
I've tried all test cases above using 2.83 alpha 2020-04-13 17:13, and even played around a bit more. It all works very nicely.
I still can't reproduce
nor
Possibly, your patch has also fixed those issues. And if not, it will at least greatly help to pin down those problems in the future.
Thanks for report, I did some more fixes in this area. I need to fix those caching issues, but I don't do editing as often, so I appreciate these reports.
