Library overrides : Overrides of Actions are not editable at all #74884
Closed
opened 2020-03-18 16:04:04 +01:00 by vprime · 15 comments
Broken: version: 2.83 (sub 8), branch: master, commit date: 2020-03-10 19:12, hash: f9cca12886
You cannot edit keyframes on a Linked Rig with Library Override
  • Open a new instance of Blender
  • Delete the Cube
  • Link the collection ot the attached file
  • Go to Object -> Relations -> Make Library Override... and selected the Mively BODY RIG
  • Go to Pose Mode
  • Added two location rotation keyframes for one of the Bones
    They play properly BUT cannot be moved in timeline, dope sheet and graph editor
    And the "Delete Keyframes" button does not work but "Clear keyframes" from the right click panel works
Mively solo.blend
**Blender Version** Broken: version: 2.83 (sub 8), branch: master, commit date: 2020-03-10 19:12, hash: `f9cca12886` Worked: (optional) **Short description of error** You cannot edit keyframes on a Linked Rig with Library Override **Exact steps for others to reproduce the error** - Open a new instance of Blender - Delete the Cube - Link the collection ot the attached file - Go to `Object -> Relations -> Make Library Override...` and selected the `Mively BODY RIG` - Go to Pose Mode - Added two location rotation keyframes for one of the Bones They play properly BUT cannot be moved in timeline, dope sheet and graph editor And the "Delete Keyframes" button does not work but "Clear keyframes" from the right click panel works [Mively solo.blend](https://archive.blender.org/developer/F8415903/Mively_solo.blend)
Author
Added subscriber: @V-prime
Member
Added subscriber: @ankitm
Member
Member
Please add a blend file to help redo the bug
Author
Tried with a linked 'one bone armature on a cube' and keyframe scaling works fine !
Issue exists on the particular set of rigs only... will upload blend tonight
Tried with a linked 'one bone armature on a cube' and keyframe scaling works fine ! Issue exists on the particular set of rigs only... will upload blend tonight
Author
Mively solo.blend
Link the collection in this file ,
Override libraries on the rig
add keyframes
try to delete/scale grab
[Mively solo.blend](https://archive.blender.org/developer/F8415903/Mively_solo.blend) Link the collection in this file , Override libraries on the rig add keyframes try to delete/scale grab
Member
Added subscriber: @mano-wii
The manual says that Library Orverrides is Experimental, with known issues and many ToDos.
https://docs.blender.org/manual/en/latest/files/linked_libraries/library_overrides.html
I didn't find anything specific about what was explained in the report, and the problem seems to be somewhat important.
So I dare mark it as a bug.
Maybe it could be a task of #73318 (Library overrides)
The manual says that Library Orverrides is Experimental, with known issues and many ToDos. https://docs.blender.org/manual/en/latest/files/linked_libraries/library_overrides.html I didn't find anything specific about what was explained in the report, and the problem seems to be somewhat important. So I dare mark it as a bug. Maybe it could be a task of #73318 (Library overrides)
Added subscriber: @lrevardel
@V-prime I did investigate a similar issue in the past. The reason why your blend file dos not behave like a simple cube/amature setup is because your armature in "Mively Solo.bend" file has an action attached to it (you might have tried some animation and save the file). If you remove this action (go to "blender file" view in the outliner to find "Mively BODY RIGAction") and save the file, you'll be able to edit keyframes in a fresh linked version of it. Note this is just a warkaround, this is a limitation of the system and should be addressed.
It looks to me that the root cause is related to #72629.
@V-prime I did investigate a similar issue in the past. The reason why your blend file dos not behave like a simple cube/amature setup is because your armature in "Mively Solo.bend" file has an action attached to it (you might have tried some animation and save the file). If you remove this action (go to "blender file" view in the outliner to find "Mively BODY RIGAction") and save the file, you'll be able to edit keyframes in a fresh linked version of it. Note this is just a warkaround, this is a limitation of the system and should be addressed. It looks to me that the root cause is related to #72629.
Added subscriber: @mont29
Note that you will never be able to edit keyframes in an override action, only (later) add or replace some F-curves...
Bastien Montagne changed title from Library overrides : Keyframes refuses to grab, scale, drag or delete normally to Library overrides : Overrides of Actions are not editable at all 2020-07-15 11:32:12 +02:00
Closed as duplicate of #72629
5 Participants
Reference: blender/blender#74884
