Python curve hook operators mess with selection (Probably only on Windows)
Confirmed, NormalPublicBUG
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.83 (sub 9), branch: master, commit date: 2020-03-15 22:43, hash: rBf06a6e92bc5e
Worked: I tried an older version which I know to have worked on my Linux machine at work a few days ago, and it still didn't work, so I suspect this issue is only present on Windows, or only on my computer. Let me know if you can reproduce.
  • Run the python script curve_select_fail.py.
  • Hook modifiers get added. According to the code, the modifiers should correspond to each curve point. Instead, the result is random - most of the time, but not always, only the first point is hooked with all of the modifiers.
  • Run the python script why_index_error.py
  • It index errors. If you remove the last line of code, it works. The last line of code shouldn't affect the curve's indicies, so this can't be right.
I could really use a workaround until this is fixed.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.EditedThu, Mar 19, 11:00 PM
The problem is quite complex.
The operator OBJECT_OT_hook_add_selob calls ED_curve_editnurb_load which creates another cu->nurb and free the old one.
But the old cu->nurb is already referenced by a PyObject of type pyrna_prop_collection_Type with pointer inited in rna_Curve_splines_begin.
The ideal would be, when freeing the pointer, to call RNA_POINTER_INVALIDATE(nu_ptr) for the original PointerRNA.
But the question is, how to find this PointerRNA in the operator?
@Campbell Barton (campbellbarton), we need an RNA/CPython expert here.
Or maybe we don't even need free cu->nurb
Thanks for looking into it! Were you able to reproduce it on Linux as well? I could swear that this worked on my work computer just a few days ago... I will check if I get the chance, but working from home atm >.>.
In the meanwhile, based on your description of the issue, I managed to work around it by re-grabbing my reference to the object, spline and curve points after running the Add Hook operator.
