3D Viewport: Jump, when mouse crosses a window corner
Confirmed, LowPublicBUG
Operating system: Windows 10, 64bit
Graphics card: none (CPU)
Broken: (v 2.82a) and also (v 2.83 Alpha, Date 2020-03-18 17:16, Hash c9c08dc7c873)
Worked: Never
Possibly any operation in 3D Viewport jumps, if the mouse pointer crosses a corner (not only an edge) of the 3D Viewport window.
Typical scenario: I have zoomed in a lot to edit a detail, and I'm moving an object to the screen center using the Move the view tool. If my mouse cursor crosses the 3D Viewport window corner, the object jumps out of sight (disappears).
  • Start Blender
  • Choose 2D Animation on the splash screen (-> 2D Animation starts in camera view and draw mode)
  • Zoom out as far as possible (-> you'll see things jump, and not just dissapear)
  • Enable Display Cursor (-> seeing the cursor makes it easier to intentionally hit the corner)
  • Press the Move the view tool to move the camera view.
  • Drag the cursor across the window corner with reasonable speed (-> fast to easier hit the corner, slow to distinguish a jump from jerky mouse movement)
  • It's not quite easy to exactly hit the window corner. I correct my motion, if I see the cursor pass in the top left or bottom right corner. With practice, I get a jump about every 10th time, I pass the corner.
  • If a jump occurs, the (fully zoomed out) camera view suddenly jumps to one of the edges of the window.
Note:
This happens to me not only with draw mode, camera view and Move the view tool, but likely with any mode, view and tool of the 3D Viewport, that sometimes makes me cross the window corner. I did observe it using
  • Move the view tool
  • Zoom in/out the view tool
  • G-key command to move things
in
  • camera view
  • 3d view
  • draw mode
  • edit mode
  • maybe object mode
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Mar 23 2020, 2:14 PM
Richard Antalik (ISS) updated the task description. (Show Details)
Thanks for the report!
I'm not sure I can reproduce this. Although maybe I don't understand the steps well enough.
@Richard Antalik (ISS) or @Gabriel (gabi2002), do you mind providing a short video of the issue?
It is a bit tricky, but issue is still there.
Bastien Montagne (mont29) triaged this task as Low priority.Oct 14 2020, 1:39 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".
Here on linux I can even reproduce it on a single axis (any border, not only corners). I think this is related to hdpi mice, the current time check is a bit to strict in those cases and can still allow for double-wraps sometimes.
D9209 fixes the issues for me on Linux (X11).
Other OSs are still to be addressed, looks like X11 backend is the only one to use that time check on events to avoid doubles? Also curious whether e.g. OSX (cocoa backend) exhibits the same issue?
