Crushed Velvet Eevee render problems in Cycles #75258
2 Participants
Reference: blender/blender#75258
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version:
cf6d17a6aa
375c7dc4ca
Worked: ?
The Crushed Velvet material from the Material Library does not render properly with Cycles when setting the device to GPU.
Set the render device to GPU and render.. Depending whether you have only GPU(s) activated in the preferences or also CPU(s) you should see one of the following. When only GPU(s) are enabled you should get a proper render. When CPU(s) are also enabled you should get dark render tiles that are rendered on the CPUs.
VelvetTestSimplified2.blend
Original description:
I'm attaching the .blend file I used to test this issue. I'm not even sure this is a bug or simply me not being overly familiar with materials yet, but it feels like a bug. An dit may be a Blender bug and nothing to do with this add-on. Obviously, this material renders fine in Eevee, but it also renders fine in Cycles when using CPU to render, but has major artifacts when using GPU to render. I've attached a render to show what I'm getting in case you don't experience it.
The steps I took to get here are,
Basically, I have a default scene I use to do my modeling or as a start point. It's very basic. I was experiencing this issue in another project I was working on and noticed it went away when I changed the material on one object.
That's it. I had initially thought it was simply a problem rendering in Cycles but for my first render, I forgot to switch from CPU to GPU and noticed it rendered fine. So I did a few more tests and it renders fine with CPU every time, but not with GPU.
VelvertTest.blend
Added subscriber: @Durghan
Added subscriber: @rjg
The problem appears to be that transmission is non-zero, the IOR is zero and there is subsurface scattering. This results in a black output on CPU but not on GPU. Below is a simplified file with a simplified material where the settings of the Principled BSDF are at the default except for the Subsurface, IOR and Transmission.
This is an edge case as even with an IOR slightly above zero it renders properly on both.
My edit should perhaps be a new separate report as I've noticed that the original report had the problem in reverse, works fine on CPU but not with GPU.
