Huge memory usage when trying to paint on UVs far ouside the 0-1 range #75284
6 Participants
Reference: blender/blender#75284
Broken: version: 2.82a (sub 7), branch: master, commit date: 2020-03-12 05:06, hash:
375c7dc4ca
Worked: Never
Blender freezes when I attempt to use the paint options, after adding an image to Texture Paint. Memory will skyrocket from 150MB to 13GB and does not un-freeze.
Youtube tutorial I'm following trying to learn to paint textures, bug happens after adding the image at 2:35, and I attempt to paint the model: https://www.youtube.com/watch?v=lmbAs9jE1vI
I am very new to Blender, but pretty sure it shouldn't be doing that when attempting to use the Paint tools.
texture_paint_huge_memory_usage.blend
Added subscriber: @Mattalan
#89646 was marked as duplicate of this issue
#75452 was marked as duplicate of this issue
Added subscriber: @ankitm
Hi Matt!
That could be a memory leak, or a result of scene with superfluous details. Please add a simple blend file to help redo the bug, with steps after which the memory increases.
Thank you Ankit! I've attached the blend file I'm using.
From the Texture Paint screen, after creating a new image, I select Mode - Single Image, attach my Image file, and then when I attempt to paint the image, it freezes, then the memory spike happens, please see the image I've attached, where I've circled the step I take before it crashes.
In the Youtube link in my first post, it happens after the 2:35 time mark, where the Youtuber is able to paint their model, mine will crash.
BugToReproduce.blend
I had to force quit, when it exceeded 4 GB quickly. Got this in trace:
Freeze/Memory Spike using Paintto Huge memory usage when trying to paint large portions of a texture on a meshChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @mano-wii
The code works as designed. But it is a problem to have no safeguard or warning to avoid things like that.
The UV of your object is very high and any operation is working on the entire texture at once and several times.
Edit the UV of your object before working on the texture.
Although it's not really broken, I don't think such a problem should be ignored. At least it must be a task for #68896 (Texture painting usability)
Added subscriber: @lichtwerk
@mano-wii: I think this should be a Known Issue then?
(feel free to change back though -- but usually out-of-memory issues are not considered bugs)
Added subscriber: @Gigakb
Most of the time, it skyrockets to 20GB+ for no reason at all. I guess its a huge memory leak.
Just to make this clear: we are having UVs with values like 3000 [instead of 0-1 or at least something more sensible...]
Just quickly packing UVs here make will get rid of the memory spike:
BugToReproduce_packed.blend
I havent checked code here, and of course it would be good to reduce the cost even with huge UV maps, but still think there is no reason to have UVs with these astronomic values as well...
Added subscribers: @rjg, @DirSurya
@ankitm : not sure #75452 has the same roots... In #75452, the UVs all seem to ly inside a 0-1 range...
oh sorry, Please reopen
Huge memory usage when trying to paint large portions of a texture on a meshto Huge memory usage when trying to paint on UVs far ouside the 0-1 rangeAdded subscribers: @RangerOri, @PratikPB2123, @EAW
