File browser should accept full paths in file input #75376
9 Participants
Reference: blender/blender#75376
Operating system: windows 10
Graphics card: 2080ti
Broken: 2.82 Windows
Worked: 2.82 Linux
The file browser used to load and save files has its file path split up into 2 parts. The top of the window has a section for the folder and the bottom has a section for the filename.
To be standard with other window applications it should be possible to do everything with the bottom "file" input.
In the bottom input section user should be able to;
My apologies if this is not a bug, initially I put it on rightclickselect as a feature but someone commented saying it worked in linux so therefore may be considered a bug.
https://blender.community/c/rightclickselect/drfbbc/#5e6e02a69c1221214ad66b4a
While in windows, start blender and try to save the file by typing the whole path into the bottom file input. eg "C:\folder\file.blend"
Notice how it will save to "C:\folder\file.blend\untitled.blend"
Added subscriber: @FrankieHobbins
#71346 was marked as duplicate of this issue
#89043 was marked as duplicate of this issue
File browser should accept full paths in file inputto File browser should accept full paths in file input like in LinuxAdded subscriber: @bent
Added subscribers: @LazyDodo, @mont29
Likely some bad handling of the backslash path separator here? Anyway, would be easier for some windows dev to investigate this… gentle poke at @LazyDodo ;)
Otherwise will have to spend some time dusting off again my VM and whole blender build chain there. ;)
I always assumed this was because blender cut the path (upper part of the dialog) and filename (bottom part of the dialog) into two separate things unlike any file dialog on this platform.
The filename part is being run though
BLI_filename_make_safe
infile_filename_enter_handle
which replaces all 'bad characters' with an underscore (including/
) we sure this is actually working on linux?Added subscriber: @lichtwerk
@LazyDodo : nope, this is the same on linux (at least for me) -- forward slashes replace by underscore.
Not sure this is really a bug?
Added subscriber: @ZedDB
This is not a bug as the bottom field is only intended for filename input. (At least currently)
File browser should accept full paths in file input like in Linuxto File browser should accept full paths in file inputAdded subscribers: @jsprenkle, @dfelinto, @Zandman, @PratikPB2123, @WilliamReynish, @rjg
To add my two cents:
