Bevel weird behaviour when using bevel weights #75383
Closed
opened 2020-04-04 17:21:59 +02:00 by Henrik D. · 13 comments
Member
Operating system: Linux (Debian bullseye)
Graphics card: Nvidia GTX 1070
Broken: current master (2.83.11)
Worked: never (tested from 2.79 up)
I don't know how to put the behavior in words. It happens when 3 edges come together in a vertex and two of them have low bevel weights and one has high bevel weight. It will create some very messy geometry and flatten the bevel in a weird way. This is no technical limitation I think, because there is a clear solution how the bevel should work in this case.
I know this report could be closed as known issue, but I would rather like to see that fixed to have a more stable bevel modifier.
testbevelbug.blend
**System Information** Operating system: Linux (Debian bullseye) Graphics card: Nvidia GTX 1070 **Blender Version** Broken: current master (2.83.11) Worked: never (tested from 2.79 up) **Short description of error** I don't know how to put the behavior in words. It happens when 3 edges come together in a vertex and two of them have low bevel weights and one has high bevel weight. It will create some very messy geometry and flatten the bevel in a weird way. This is no technical limitation I think, because there is a clear solution how the bevel should work in this case. I know this report could be closed as known issue, but I would rather like to see that fixed to have a more stable bevel modifier. **Exact steps for others to reproduce the error** [testbevelbug.blend](https://archive.blender.org/developer/F8448092/testbevelbug.blend)
Author
Member
Added subscriber: @HDMaster84
Hans Goudey was assigned by Henrik D. 2020-04-04 17:22:43 +02:00
Author
Member
Added subscribers: @howardt, @AnthonyEdlin
Hi, thanks for the report.
I can confirm that it works as you describe. I'm not sure on intended behavior, prolly ask @howardt
Only other report I found was:#73028 (bevel modifier not working really well with bevel weights)
It seems that with a low bevel weight on a single edge of a cube makes it really bulge out.
Hi, thanks for the report. I can confirm that it works as you describe. I'm not sure on intended behavior, prolly ask @howardt Only other report I found was:#73028 (bevel modifier not working really well with bevel weights) It seems that with a low bevel weight on a single edge of a cube makes it really bulge out. ![bevel_modifier_low_bevel_weight.png](https://archive.blender.org/developer/F8449023/bevel_modifier_low_bevel_weight.png)
Hans Goudey removed their assignment 2020-04-05 00:09:50 +02:00
Member
We're not supposed to assign reports to people unless they are currently working on them. I don't have the headspace to work on this right now so I'm removing myself.
I agree this doesn't look like the best solution though. It would be helpful to see people create what they think the modifier should do though, because I don't think the behavior you'd like is as straightforward as you might think. It's not clear to me what direction I'd pursue to solve the problem.
Miter options might help mitigate this.
We're not supposed to assign reports to people unless they are currently working on them. I don't have the headspace to work on this right now so I'm removing myself. I agree this doesn't look like the best solution though. It would be helpful to see people create what they think the modifier should do though, because I don't think the behavior you'd like is as straightforward as you might think. It's not clear to me what direction I'd pursue to solve the problem. Miter options might help mitigate this.
For reference, I'm guessing the desired behavior is more like this: bevel_modifier_low_bevel_weight_desired.png
Done by first beveling the 2 edges and then using a second bevel modifier with a vertex group of the other edge. I'm not sure how or if this can be done internally though.
For reference, I'm guessing the desired behavior is more like this: ![bevel_modifier_low_bevel_weight_desired.png](https://archive.blender.org/developer/F8449205/bevel_modifier_low_bevel_weight_desired.png) Done by first beveling the 2 edges and then using a second bevel modifier with a vertex group of the other edge. I'm not sure how or if this can be done internally though.
Member
Member
Interesting. It looks like the middle point of the profile is being placed incorrectly, but I haven't looked into the code yet.
Hans Goudey self-assigned this 2020-05-19 16:13:24 +02:00
Member
@howardt
I've been looking into this, and it looks like a problem with the cube corner special case.
With Special Case Cube Corner Special Case Off
/bmesh_bevel.c b/source/blender/bmesh/tools/bmesh_bevel.c
index d1ddceb00b0..0d753eca675 100644
--- a/source/blender/bmesh/tools/bmesh_bevel.c
+++ b/source/blender/bmesh/tools/bmesh_bevel.c
@@ -4167,6 +4185,9 @@ static int tri_corner_test(BevelParams *bp, BevVert *bv)
   if (bv->vmesh->count != 3) {
     return 0;
+  const float offset = bv->edges[0].offset_l;
   totang = 0.0f;
   for (i = 0; i < bv->edgecount; i++) {
     e = &bv->edges[i];
@@ -4178,6 +4199,11 @@ static int tri_corner_test(BevelParams *bp, BevVert *bv)
     else if (absang >= 3.0f * (float)M_PI_4) {
       return -1;
+    if (e->is_bev && !compare_ff(e->offset_l, offset, BEVEL_EPSILON)) {
+      return -1;
     totang += ang;
   if (in_plane_e != bv->edgecount - 3) {
But the VMesh has some other issues when using the generic VMesh:
{F8543780}From the bottom
Would you agree that it makes sense to disable the cube-corner special case when the offsets aren't the same on every edge?
That doesn't feel like a complete solution by itself, but I feel like we might be running into the limitations of the ADJ method. Maybe it's time to test out another VMesh method idea I had..
@howardt I've been looking into this, and it looks like a problem with the cube corner special case. |With Special Case|Cube Corner Special Case Off | -- | -- | |![image.png](https://archive.blender.org/developer/F8543775/image.png)|![image.png](https://archive.blender.org/developer/F8543782/image.png) ```lines=5 /bmesh_bevel.c b/source/blender/bmesh/tools/bmesh_bevel.c index d1ddceb00b0..0d753eca675 100644 --- a/source/blender/bmesh/tools/bmesh_bevel.c +++ b/source/blender/bmesh/tools/bmesh_bevel.c @@ -4167,6 +4185,9 @@ static int tri_corner_test(BevelParams *bp, BevVert *bv) if (bv->vmesh->count != 3) { return 0; } + + const float offset = bv->edges[0].offset_l; + totang = 0.0f; for (i = 0; i < bv->edgecount; i++) { e = &bv->edges[i]; @@ -4178,6 +4199,11 @@ static int tri_corner_test(BevelParams *bp, BevVert *bv) else if (absang >= 3.0f * (float)M_PI_4) { return -1; } + + if (e->is_bev && !compare_ff(e->offset_l, offset, BEVEL_EPSILON)) { + return -1; + } + totang += ang; } if (in_plane_e != bv->edgecount - 3) { ``` But the `VMesh` has some other issues when using the generic `VMesh`: {[F8543780](https://archive.blender.org/developer/F8543780/image.png)}*From the bottom* Would you agree that it makes sense to disable the cube-corner special case when the offsets aren't the same on every edge? That doesn't feel like a complete solution by itself, but I feel like we might be running into the limitations of the ADJ method. Maybe it's time to test out another VMesh method idea I had..
Member
Yes, makes sense to me that the cube-corner case only makes sense if the offsets are the same on every edge.
This issue was referenced by 20c30534aa
This issue was referenced by 20c30534aafc4a97803d9e72ae765b5415fb1359
This issue was referenced by c554f4e14f
This issue was referenced by c554f4e14fce679e047fd8ee75368548de70d0cb
Member
5 Participants
Reference: blender/blender#75383
