Bone selection behaves poorly #75425
9 Participants
Reference: blender/blender#75425
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash:
375c7dc4ca
Worked: version: 2.81
Since version 2.82 the bone selection behavior has changed so that it is unnecessarily hard or even impossible to select certain bones.
Old behavior: Bones were selected if the area or edge of a bone was clicked. If multiple bones of different size are stacked inside of each other, it was easy to select any of them with a single click.
New behavior: The bone selection cycles through all the bones below the mouse cursor, starting with the biggest(?), regardless of the area that was clicked. If the cursor is moved between clicks the cycle starts anew, no matter which bone was selected last. This way several clicks are needed almost everytime to select the intended bone.
The attached file includes a setup of three bones.
(box/circle/lasso select kinda work but trying to select a single bone with those should not be a thing)
boneSelection.blend
Added subscriber: @TomL
#79024 was marked as duplicate of this issue
This issue was referenced by
bd59781c66
Added subscriber: @moisessalvador
This only solves the cycling, but not what bone is supposed to be selected first for both pose mode and edit mode. If a bone is inside another and your mouse is over the smaller bone inside, the old behavour would be for the smaller bone inside to be selected first. This new behaviour makes it harder in some rigging scenarios where the order of active or selected bones matter.
Added subscriber: @Floreum
I've made a little demonstration of how selecting overlapping bones currently works versus how it used to work in 2.80. This behavior is in both edit and pose mode which makes creating parenting or constraints tricky to do.
BlenderSelectionBug.mp4
Glad i'm not the only one struggling with this.
Another case where the new selection system fails is when you use left click select and a gizmo is active. Since you can't select the specific bone you want with a single click anymore, the gizmo will now appear under the cursor and you can't start cycling through bones. This leaves you with scrolling, rotating around the bones or tool changing to either find an angle where the gizmo is not in your way or get rid of the gizmo for a moment.
The old selection understood and supported the users actions. The change feels like a huge step backwards, making selections tedious and more time consuming. By the amount of selections that are made while rigging this really adds up.
Added subscribers: @dfelinto, @CobraA
Yep this doesn't seem to be resolved at all, it's actually cascaded to 2.83 & 2.90, the 2.81 has the "correct" proper way.
@dfelinto Can you guys re-take a look at this?
Added subscriber: @SecuoyaEx
Whatever happened to this? What we're asking is simple. Let bones be selectable by the closest wire to the mouse cursor, like Objects in wireframe mode already are, not just by their closest zdepth surface.
Why is this a problem? Because it means that everything BUT bones are selectable by their wire. And you guys like consistency, right? That oughta convince ya 😏
And changing the viewport display mode of the object does nothing, so that doesn't help either. It should work on both wireframe shading and per object wireframe display, no brainer.
Added subscribers: @LDsanya, @mano-wii
This has been solved. Re-opening #79024 since it describes the other issue.
