Exporting gltf with draco compression messes up the vertex color #75550
Closed
opened 2020-04-09 14:06:34 +02:00 by Jesper van den Ende · 7 comments
Operating system: Darwin-19.4.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 460 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.8.24
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-08 21:23, hash: blender/blender@1239cab11f
When exporting a mesh with vertex colors as glb with draco compression enabled. The exported vertex color is different from what it should be. I haven't been able to import the exported glb into blender to check if this is a bug with blender or if it's an issue with three.js. But my exported mesh fails to render correctly both in https:*threejs.org/editor/ as well as on https:*gltf-viewer.donmccurdy.com/ and on https://sandbox.babylonjs.com/
  • Create a simple mesh with vertex colors (see attached blend file)
  • Export as glb
  • Export again as glb but with draco mesh compression enabled
  • Notice how vertexColorTest.glb works fine on the websites mentioned above, but how vertexColorTestCompressed.glb doesn't.
Additional info
https://gltf.insimo.com/ has an implementation of draco mesh compression with working vertex colors. Notice how 'vertexColorTest insimo.glb' works on all sites mentioned above.
vertexColorTest.blend
vertexColorTest.glb
**System Information** Operating system: Darwin-19.4.0-x86_64-i386-64bit 64 Bits Graphics card: AMD Radeon Pro 460 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.8.24 **Blender Version** Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-08 21:23, hash: `blender/blender@1239cab11f` Worked: (newest version of Blender that worked as expected) **Short description of error** When exporting a mesh with vertex colors as glb with draco compression enabled. The exported vertex color is different from what it should be. I haven't been able to import the exported glb into blender to check if this is a bug with blender or if it's an issue with three.js. But my exported mesh fails to render correctly both in https:*threejs.org/editor/ as well as on https:*gltf-viewer.donmccurdy.com/ and on https://sandbox.babylonjs.com/ **Exact steps for others to reproduce the error** - Create a simple mesh with vertex colors (see attached blend file) - Export as glb - Export again as glb but with draco mesh compression enabled - Notice how vertexColorTest.glb works fine on the websites mentioned above, but how vertexColorTestCompressed.glb doesn't. **Additional info** https://gltf.insimo.com/ has an implementation of draco mesh compression with working vertex colors. Notice how 'vertexColorTest insimo.glb' works on all sites mentioned above. [vertexColorTest insimo.glb](https://archive.blender.org/developer/F8459626/vertexColorTest_insimo.glb) [vertexColorTest.blend](https://archive.blender.org/developer/F8459629/vertexColorTest.blend) [vertexColorTest.glb](https://archive.blender.org/developer/F8459628/vertexColorTest.glb) [vertexColorTestCompressed.glb](https://archive.blender.org/developer/F8459627/vertexColorTestCompressed.glb)
Added subscriber: @jespertheend
Added subscriber: @mano-wii
Inport/Export glTF Addon has its own channel for bug reports:
https://github.com/KhronosGroup/glTF-Blender-IO/issues/
You can be more successful there.
Inport/Export glTF Addon has its own channel for bug reports: https://github.com/KhronosGroup/glTF-Blender-IO/issues/ You can be more successful there.
Thanks for the heads up!
I created an issue over there https://github.com/KhronosGroup/glTF-Blender-IO/issues/1019
Thanks for the heads up! I created an issue over there https://github.com/KhronosGroup/glTF-Blender-IO/issues/1019
Member
Added subscriber: @JulienDuroure
Member
Julien Duroure self-assigned this 2021-01-04 21:00:18 +01:00
Member
This is fixed by eb29a12da4
This is fixed by eb29a12da48e
Reference: blender/blender-addons#75550
