Keymap Preference Menu Disappearance #75624
Reference: blender/blender#75624
Operating system: Windows 10
Graphics card: NVidia GTX 980
Broken: 2.82a
Worked: NA
Hello,
Once I edit the keymap with my custom setup the preference menu disappears.
Load the custom keymap Blender Key Configuration.py
Best,
Orso
Added subscriber: @roberto.loriga
Added subscriber: @TheRedWaxPolice
Afaik, that's intentional...
Hi, can you explain to me why it is like that? I'd prefer to have the ability to change those parameters even after changing the default shortcuts. Most are not related to the shortcuts I changed.
The few changes I made are to avoid using a combination of keys to do basic viewport movements: right click opens the context menu but rmb drag rotates the view; pan with mmb drag and scroll to dolly. I then used the same scheme for other modes. That's it, I should retain the ability, for example, to toggle "Extra Shading Pie menu Items" etcetera.
Closed as duplicate of #65121
Added subscriber: @iss
I can not really explain in great detail, but technically these settings don't really need to be unavailable if you make any change, but it is not safe to assume they will work as expected afterwards.
If you change keymap, it is possible that you overwrite a map generated by function based on settings with hard-coded key, so change in setting will not apply anymore.
