OptiX shading artifacts with large simple objects #75636
Closed
opened 2020-04-11 23:59:30 +02:00 by Alaska · 5 comments
Member
System Information:
Operating system: Windows 10
Graphics card: RTX 2070 Super 442.19
Operating system: Linux (POP!_OS 18.04)
Graphics card: GTX 1050ti 440.64 (Tested with CYCLES_OPTIX_TEST=1)
Broken: 2.82, 2.83 (a8d139ca20)
Short description of error:
OptiX will produce shading artifacts on large low poly objects. This does not occur in CUDA or CPU rendering.
Here's some examples:
CPU rendering (Large Plane)
OptiX (Large Plane)
CPU rendering (Very large cube)
OptiX rendering (Very large cube)
Exact steps for others to reproduce the error:
  1. Open a new Blender instance.
  2. Change the render engine to Cycles with GPU compute with OptiX and switch to viewport rendering (also occurs in final renders F12).
  3. Delete the default cube and lamp.
  4. Create a plane (or some other low poly object) and a sun light (The sun seems to be the easiest light to notice with)
  5. Scale up the plane a large amount. (I had to increase mine to about 10000mx10000m to see this effect in some scenes. In others, only 500mx500m). You should now see shading artifacts. If you don't see them, try changing the rotation of the sun.
  6. If you then sub-divide the mesh a bunch, the artifacts seem to go away.
Here's a simple .blend file (notice how the cube is much darker in OptiX than CUDA or CPU):
OptiX Shading Errors.blend
**System Information:** Operating system: Windows 10 Graphics card: RTX 2070 Super 442.19 Operating system: Linux (POP!_OS 18.04) Graphics card: GTX 1050ti 440.64 (Tested with CYCLES_OPTIX_TEST=1) **Blender Version** Broken: 2.82, 2.83 (a8d139ca2002) **Short description of error:** OptiX will produce shading artifacts on large low poly objects. This does not occur in CUDA or CPU rendering. Here's some examples: ![CPU.png](https://archive.blender.org/developer/F8465760/CPU.png) CPU rendering (Large Plane) ![Optix 1.png](https://archive.blender.org/developer/F8465762/Optix_1.png) OptiX (Large Plane) ![CPU 2.png](https://archive.blender.org/developer/F8465761/CPU_2.png) CPU rendering (Very large cube) ![OptiX 2.png](https://archive.blender.org/developer/F8465763/OptiX_2.png) OptiX rendering (Very large cube) **Exact steps for others to reproduce the error:** 1. Open a new Blender instance. 2. Change the render engine to Cycles with GPU compute with OptiX and switch to viewport rendering (also occurs in final renders F12). 3. Delete the default cube and lamp. 4. Create a plane (or some other low poly object) and a sun light (The sun seems to be the easiest light to notice with) 5. Scale up the plane a large amount. (I had to increase mine to about 10000mx10000m to see this effect in some scenes. In others, only 500mx500m). You should now see shading artifacts. If you don't see them, try changing the rotation of the sun. 6. If you then sub-divide the mesh a bunch, the artifacts seem to go away. Here's a simple .blend file (notice how the cube is much darker in OptiX than CUDA or CPU): [OptiX Shading Errors.blend](https://archive.blender.org/developer/F8465783/OptiX_Shading_Errors.blend)
Author
Member
Added subscriber: @Alaska
Added subscriber: @Pasang
Added subscriber: @brecht
Brecht Van Lommel self-assigned this 2020-05-14 14:29:10 +02:00
This is a general ray tracing precision problem, we want to improve this (e.g. D6250) but it's not considered a bug.
This is a general ray tracing precision problem, we want to improve this (e.g. [D6250](https://archive.blender.org/developer/D6250)) but it's not considered a bug.
Reference: blender/blender#75636
