Graph Editor : limitation of Bézier Handles #75881
13 Participants
Reference: blender/blender#75881
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 980 Ti OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.33.0 387.10.10.10.40.105
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash:
375c7dc4ca
Also broken in previous version and also 2.90 alpha
Worked: Never (2.79+)
In the Graph Editor the bézier handles are meant to be pulled to shape the f-curve.
Currently it seems these handles have a threshold/limitation that prevent strong manipulation.
This is a real shortcoming for animation work.
{F8482261, size=full}
{F8482322, size=full}
Open attached .blend file.
Playback and observe the motion difference (here the desired motion is accomplished by adding more keyframes).
Scaling the handles can never accomplish the desired curve.
It should be possible like this :
Bezier_limitation.blend
Added subscriber: @antoine.grasset
Added subscriber: @ankitm
Added subscriber: @iss
I can't seem to get this desired curve shape even in 2.79 version, but I can't believe nobody reported this yet.
Added subscriber: @StanislavOvcharov
To my knowledge it was never doable, I just tested as far as Blender 2.57 to check.
It's been reported on several discussions forums but never here.
Added subscriber: @dr.sybren
I wouldn't classify this as a bug, rather as a known limitation. And yes, it's quite a big limitation.
Fixing this would require great care in the versioning code, in order to ensure that existing animations aren't changed. I think with some clever math, this is quite doable, though.
Added subscriber: @LucianoMunoz
It would be great to have this fixed, because it means that less keyframes are necessary to achieve particular moves, and the less keyframes we need to make the less time takes to animate, polish etc.
@dr.sybren Thank you for acknowledging the limitation !
Do you know how likely an unassigned known issue is to be processed ? (I'm quite new here)
I'm willing to have a look (though relatively new to Python), can you advise were to look to modify the curves' behaviour ?
Added subscriber: @CobraA
It's a feature request on RCS, the workaround that people suggested to me is to add another keyframe in each middle.
Absolutely, I commented on it on RCS to revive the thread after a year of inactivity : https://blender.community/c/rightclickselect/0Ccbbc/
And you're right : adding a keyframe in the middle is the only way to achieve the result and being able to fine-tune it.
I'm hoping this can be improved, I think it can make animating a lot more fluid and elegant.
Added subscriber: @Oskar3d
Removed subscriber: @antoine.grasset
Added subscriber: @dinhdong
Added subscriber: @bent
After reading about the F-curve through this link. It seems I have understood the reason. Here are the relevant key excerpts from the link above :
They're normal Bézier curves with certain restrictions placed on the positions of the handles...
This guarantees that the curve will not turn back on itself.
On line 1830, the correct_bezpart() function begins. The function finds the width of each handle and the width between the two keyframes. If the combined width of the two handles is greater than the width between the two keyframes, then the two handles are scaled down so that they don't cross each other, but their relative lengths are preserved. The original handles are used for drawing to the graph editor, but the scaled-down versions are used for generating the curve, a plain-old cubic Bézier curve."
I think this restriction needs to be corrected. In adobe AE, two handles can move freely, as long as their time value (x value) is not less than the value of the first keyframe and not greater than the value of the second keyframe :
Thanks a lot Dinh Dong ! The post you linked explains it really well indeed.
F-curves are beziers that must not loop or rewind against the flow of time = example of forbidden curve .
To avoid this, f-curves are processed at eval-time by the function "correct_bezpart()" called in fcurve.c (line 1630) .
By checking the corresponding code you can see that it was assumed that to prevent the beziers from looping they had to be limited when :
len1 + len2 > len
This assomption turns out to be wrong and unnecessarily limits the handles. Instead they should be constrained as follow :
0 < len1 < len
and0 < len2 < len
Try it for yourself
here is the current limited behaviour
here is the corrected proposal (note that the curve cannot loop/rewind)
I created a patch that corrects the bezier behaviour and makes animating a lot easier : D8752: Graph Editor : Fix for f-curves limitation
The caveat is that existing animation can now render differently because the handles have more range.
@dr.sybren Do you recommend detecting if blend files were created in previous versions ? or some kind of updating trick to rebake the handles with their previously limited value ?
Added subscriber: @wbmoss_dev
This issue was referenced by
da95d1d851
For the release notes: #75881-fcurve-limits-demo.mp4
This issue was referenced by None@62484
Added subscriber: @Saiman
Hi. Could you add the possibility to change the curve as shown in the video? In Maya, the curve can be changed more flexibly. It can be almost the vertical on all animation's length between two frames.
Comp 1_1.mp4
