When exporting models, global transformation matrix is automatically applied, with no option to change it. #75903
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#75903
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.02
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash:
blender/blender@f1aa4d18d4
Addon Information
Name: Wavefront OBJ format (3, 7, 0)
Author: Campbell Barton, Bastien Montagne
When you export a .obj file using this plugin, the vertices are exported in world coordinates instead of local coordinates, which causes issues when importing into other applications. There is no option to change this, so it is the only way you can export any models.
Simply move a cube to any location other than the origin, then export as .obj with all the default settings. The cubes exported file contains vertex information that is in world coordinates instead of local coordinates. I have added an option in my local version of this file, but I think you should add it to the actual program.
In init.py line 313 I added
and at line 354 I added
Then in export_obj.py I added the options in the export functions called:
Then, I added a simple if statement around the global transformation application around line 365:
Please consider adding this option to the plugin, I have laid out all the necessary steps, albeit I may have missed some, but it's not that complicated and will hopefully help future developers from being misled about the contents of their exported OBJ files.
Added subscriber: @ambrosiogabe
Added subscriber: @ankitm
If that is working correctly, you may submit a patch at https://developer.blender.org/differential/diff/create/. Also read the links given at the top for guidance.
