MatCap inverts if Viewport Display Metallic and Roughness are set below certain threshold #75938
Reference: blender/blender#75938
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-20 02:11, hash:
23bb42a06e
Worked: 2.82a
MatCap inverts if Viewport Display Metallic and Roughness are set below certain threshold.
Change Viewport Shading to MatCap, select Cube, go to Material Properties to Viewport Display, set Metallic and Roughness to 0. Metallic can be as low as 0.144.
Added subscriber: @MarcZbinden
Added subscriber: @fclem
The issue is the following part of the workbench_composite_frag.glsl
It changes the normal direction based on the data stored in the alpha channel. This appears to be incorrect for two reasons:
materialData.a = float(gl_FrontFacing);
is only set ifuseMatcap
is true. Despite its name, the variable is not always set to true when matcaps are used. It is only set to true forhaircertain shading groups inworkbench_opaque_cache_init
([ https:*developer.blender.org/diffusion/B/browse/master/source/blender/draw/engines/workbench/workbench_opaque.c | workbench_opaque.c ). As a result the alpha channel instead contains thepacked_rough_metal
, which is why the values for roughness and metal impact the direction of the normal.workbench_normal_encode(gl_FrontFacing, normal_interp)
already includes backface/frontface information (see https:*developer.blender.org/diffusion/B/browse/master/source/blender/draw/engines/workbench/shaders/workbench_common_lib.glsl ). If I'm not mistaken that makes the (potential) normal inversion in the [ https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/engines/workbench/shaders/workbench_composite_frag.glsl | workbench_composite_frag.glsl redundant.If the
N = (mat_data.a > 0.0) ? N : -N;
is indeed redundant, then it could simply be removed along with thematerialData.a = float(gl_FrontFacing);
. If it isn't redundant, thenif (useMatcap)
should be replaced with a check that is always true when matcaps are used. This means either a different check/macro oruseMatcap
needs to be set to true for more cases than justhairthe current shading groups.@fclem Could you take a quick look and tell me which approach you would prefer?
We used the double inversion because users asked for it. It is indeed a strange thing but it's by design.
I think it's just a matter of adding
DRW_shgroup_uniform_bool_copy(grp, "useMatcap", use_matcap);
somewhere.@fclem Good to know. I will set
useMatcap
in the patch then.This issue was referenced by
0dfe30502a
