Multiple issues with Parenting objects chapter #75966
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#75966
While reading https://docs.blender.org/manual/en/latest/scene_layout/object/properties/relations/parents.html I noticed the following things:
The subsection "Object (Keep Transform) Parent" describes selecting with RMB instead of the now default LMB
The text under "Object Parent" says
a. The sentence starting "If will" should start "It will"
b. I guess technically it's the active object that is used as the parent object, although in most cases the last selected object is also the active one (but for example changing the selection using right-clicking in the outliner can alter the selection without changing the active object). In the introduction under "Make Parent" the active object is correctly mentioned.
Under "Make Parent" the Shift-Ctrl-P shortcut is mentioned, but that doesn't seem to work for me with 2.82.7. No matter how many objects I select Shift-Ctrl-P never creates a parenting relation for me.
Similar to point 3 the shortcut Alt-O under "Move Child" also doesn't seem to work for me when having a child selected. Or at least I can't seem to create a parenting situation in which Alt-O has any effect (never see a child move)
The description under Parent Inverse suggests that not using the parent inverse is a separate mode of parenting, but isn't it merely that the parent inverse is the identity matrix initially? I.e. even when parenting with using the parent inverse matrix that doesn't change after parenting even when the parent is transformed.
Added subscriber: @PaulMelis
Added subscriber: @Alaska
I believe I have fixed many of these issues in rBM6545
Note: I am working on updating the manual to Blender 2.8X here: #75511
