Gizmo line_width does not work in latest version #76045
Closed
opened 2020-04-24 11:34:37 +02:00 by Cédric · 19 comments
Member
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-04-23 21:07, hash: d712f1f83a
Worked: 2.83 (sub 13), branch: master, commit date: 2020-04-20 02:11, hash: 23bb42a06e
The Gizmo line_width option is not working in the latest blender version 2.83
Open the file with the script gizmo_operator.py modified for the exemple :
  • line 132 to 138 : the circle is replaced by a cross, draw_options={"FILL", "ALIGN_VIEW"} and the line_width = 15
    Select the cube and go in edit mode
    Launch the script and then using F3, search for the operator : Select Side of Plane
    You should see a fat cross in the middle
Gizmo_line_width_bug.blend
Thanks a lot for your help.
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87 **Blender Version** Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-04-23 21:07, hash: `d712f1f83a` Worked: 2.83 (sub 13), branch: master, commit date: 2020-04-20 02:11, hash: `23bb42a06e` **Short description of error** The Gizmo line_width option is not working in the latest blender version 2.83 **Exact steps for others to reproduce the error** Open the file with the script gizmo_operator.py modified for the exemple : - line 132 to 138 : the circle is replaced by a cross, draw_options={"FILL", "ALIGN_VIEW"} and the line_width = 15 Select the cube and go in edit mode Launch the script and then using F3, search for the operator : Select Side of Plane You should see a fat cross in the middle ![Gizmo_line_width_bug.jpg](https://archive.blender.org/developer/F8492322/Gizmo_line_width_bug.jpg) [Gizmo_line_width_bug.blend](https://archive.blender.org/developer/F8492313/Gizmo_line_width_bug.blend) Thanks a lot for your help.
Author
Member
Added subscriber: @Clarkx
Added subscriber: @ZedDB
I can not reproduce the issue with the steps provided.
I:
  1. Open up the file.
  2. Run the script
  3. Go in and out of edit mode
  4. Nothing happens, no cross.
I can not reproduce the issue with the steps provided. I: 1. Open up the file. 2. Run the script 3. Go in and out of edit mode 4. Nothing happens, no cross.
Author
Member
Sorry, my bad, you have to launch the script and then using F3, search for the operator : Select Side of Plane
Thanks @ZedDB
Sorry, my bad, you have to launch the script and then using F3, search for the operator : Select Side of Plane Thanks @ZedDB
Member
Member
Code probably needs some fixes/adjustments after d712f1f83a.
@Clarkx I still can reproduce. Even when I run the "Select Side of Plane" operator, no cross is visible.
With the latest build I:
  1. Open the file
  2. Run the script (doesn't seem to matter if I go in and out of edit mode)
  3. Run the operator
  4. Nothing happens.
@Clarkx I still can reproduce. Even when I run the "Select Side of Plane" operator, no cross is visible. With the latest build I: 1. Open the file 2. Run the script (doesn't seem to matter if I go in and out of edit mode) 3. Run the operator 4. Nothing happens.
Author
Member
Well, I really don't understand.. You have to be in edit mode, for sure, for the script to work.
You do have the 'Show Gizmo' toggle in the header ?
This is what I do :
Thanks again for taking the time.
Well, I really don't understand.. You have to be in edit mode, for sure, for the script to work. You do have the 'Show Gizmo' toggle in the header ? This is what I do : ![2020-04-28_14-57-13.gif](https://archive.blender.org/developer/F8499104/2020-04-28_14-57-13.gif) Thanks again for taking the time.
Author
Member
Hi @ZedDB Sorry to bother you. Just for my understanding, is there anything more I can or should do to help ? Or may be this is not a bug ?
I have been occupied with other tasks, I'll try to get back to this and see if I can reproduce before the end of this week.
Sorry for taking so long to get around to this.
I have been occupied with other tasks, I'll try to get back to this and see if I can reproduce before the end of this week. Sorry for taking so long to get around to this.
Still can't reproduce this, show gizmos are on:
recording.mp4
Still can't reproduce this, show gizmos are on: [recording.mp4](https://archive.blender.org/developer/F8503443/recording.mp4)
Author
Member
You should report a bug :o) The gizmo operator is one of the templates provided with Blender. Maybe the gizmo size in your preferences is reduce to the minimum ?
Author
Member
Hi @JulianEisel @ZedDB I'm trully sorry, I know you guys have a lot to do, but I don't know what I can do more. This is still broken in the last build and this report still say that you need information.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscribers: @fclem, @Jeroen-Bakker
I can't reproduce it.
So I guess perhaps @Jeroen-Bakker @fclem can reproduce it or have any hunch what is wrong?
I can't reproduce it. So I guess perhaps @Jeroen-Bakker @fclem can reproduce it or have any hunch what is wrong?
Clément Foucault self-assigned this 2020-05-07 17:38:33 +02:00
This issue was referenced by 933c721ccb
This issue was referenced by 933c721ccbe32e97e6125eb1068d9cdca1b33de6
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
5 Participants
Reference: blender/blender#76045
