Black material + render view with heavy scene + fog #76253
Reference: blender/blender#76253
Operating system: Windows 10
Graphics card: 1080 ti
Broken: 2.82.7
Worked: 2.82.7
Scene was working normally when the file was actively being put together, and renders were already made.
Scene now goes black when put into material preview or render view mode (eevee).
If the large cube covering the entire scene with fog material is deleted, it leaves behind this:
So far, I have tried:
Seems to only happen in this very large file, and though it doesn't contain anything sensitive, it was made at work, so I can't just publicly post it. If a developer wants to look at it, please contact me in PM here or on devtalk/BA and I will send you the file.
Added subscriber: @RobertS
Added subscriber: @Alaska
Are you able to test the file in Blender 2.83 and 2.90 to see if you can reproduce it? https://builder.blender.org/download/
You could also try updating your graphics drivers to see if that'll help. https://www.nvidia.com/Download/index.aspx
Just throwing some ideas out there.
Added subscriber: @mano-wii
Thanks for the report. But due to the number of reported bugs, it is not worth it to spend a lot of time on reports that we cannot reproduce.
Large files are not suitable for investigating a bug, we require the bug reporter to narrow down the problem.
Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly.
If there are many steps to reproduce the problem, please attach a simple .blend file saved right before the bug occurs, so only a few steps are needed to trigger the bug.
So I guess this reply is futile now but I suspect the issue is the shader compilation and the sheer size of the file... the shader subsystem seems to give up before it's even started (progress bar never shows up)... which in that case would mean it's not possible to produce a simplified setting because the bug only appears in very heavy files.
Ok, so with a bit of fiddling in 2.9, I can get the file working again... seems to not be the shader compilation, but something with the sheer size of the area and the fog volume/bloom:
This is still seems like a no-go in 2.82... tweaking the cameras and clipping planes do not seem to work there.
Seems an extremely large far clipping plane distance was saved with the file for some reason (fairly sure Blender-GIS set it... but also, fairly sure that shouldn't produce this result).
This can be the same issue reported on #74302
Yes, seems very similar, if not the same!
My file opens in black & white every time as well, so if you are going to investigate the other issue, let me know if you want the file via some private channel (and which one in that case).
Closed as duplicate of #74302
