Face sets operators not working from python console #76324
6 Participants
Reference: blender/blender#76324
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13587 Core Profile Context 20.4.2 26.20.15029.27016
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-01 21:55, hash:
83304e4c22
i tried to apply face sets via a addon and noticed that when i run any of the face sets operators it does nothing. i then tried to run them from the python console within blender and it just returns a {PASS_THROUGH} but nothing is applied to the model.
add suzanne to your scene and make sure its active
enter sculpt mode
use the Face Maps > Init Faces Set > By Loose parts
note how all loose parts get a face set, this is what is expected.
now undo the face sets again and try the same via the python console
go to the python console and enter
Added subscriber: @DanielGrauer
Added subscriber: @ankitm
https://docs.blender.org/api/current/bpy.ops.sculpt.html
Is that supported by the API ?
Also, since you asked it on support channel, I'm tempted to close it as support request.
Added subscriber: @RodDavis
https://docs.blender.org/api/2.83/bpy.ops.sculpt.html
Facesets should be supported in the 2.83 api. I'm guessing there is something stopping it for the time being.
Added subscriber: @iss
@DanielGrauer I think what you need to do is override context of operator. It is probably "confused" by instruction to select face masks in console https://docs.blender.org/api/current/bpy.ops.html#overriding-context
I will change status and ask you to check if my info helped you to resolve this issue
@iss
i was looking into the context and when i print the mode and the active obejct it gives me the correct context. i have not tried overriding it since it seems to be correct. might there be some other context that confuses the operator?
import bpy
print(bpy.context.active_object) > <bpy_struct, Object("FrontCasing")> (the correct active object)
print(bpy.context.mode) > SCULPT
bpy.ops.sculpt.face_sets_init(mode='LOOSE_PARTS')
Faces sets Pass through.blend
Here is a short demo file using facesets. It has a text file using loose parts. Just to make it a little more clear and quick.
Yes, selected object and mode are "global". Problem is that editor from within you run operator is not.
The idea of overriding context is that you want to trick operator that it is executed from different editor
you nedd to do something like
bpy.ops.transform.seq_slide({'area':editor_area}, value = (0,distance))
and you have to search foreditor_area
.i tried to override the context as in the documentation ( https://docs.blender.org/api/current/bpy.ops.html#overriding-context ) and also the way you described but i can not get it to work.
I thought there may be some issue, but after digging in code it seems, that there isn't.
Turns out, that you don't even need to override context, but rather execution context https://docs.blender.org/api/current/bpy.ops.html#execution-context
Pass
'INVOKE_DEFAULT'
as first parameter.bpy.ops.sculpt.face_sets_create('INVOKE_DEFAULT', mode='VISIBLE')
I have done this only 2 times really so I don't know much about this off top of my head. Sorry for misleading you.
Unfortunately unless you look at operator code, you don't really know if you want to call
invoke()
orexec()
function and this is kinda low-level even for quite advanced users.Sometimes you may need to override both contexts I guess.
This issue was referenced by
7f5570ceff
Changed status from 'Archived' to: 'Resolved'
Added subscriber: @brecht
There actually was a bug here, though the operator API is not strictly defined enough for it to be clear. By convention operators should always implement
exec()
for non-interactive execution, with only a few exceptions.Thanks for clarification. I have seen quite a few operators without exec function, so I probably wouldn't consider this a bug (not working as designed)
Makes sense to consider this a bug though, so I will keep it in mind.
