Keyframes with stereoscopy button doesn't work in animation, individual frame works #76353
6 Participants
Reference: blender/blender#76353
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-01 14:06, hash:
60741cfe18
Worked: never, tested 2.75a (when Stereoscopy was introduced) and 2.79
Whole animation is render with stereoscopy ignoring on/off animation keyframes.
with stereoscopy "on" insert a keyframe on it, move few frames and turn off stereoscopy and insert a keyframe. While rendering animation (my setup is FFmpeg with mp4 coding) all frames are rendered as stereoscopic. I attached an example file with render result. I was expecting to have half of this animation as stereoscopic and half normal. Originally I discovered it in a situation where I was swapping cameras (binding to video marker).
Open file, render frames 39-40-41 individually.
in viewport change set frame to 39
Render animation (5 frames)
in viewport, set frame to 41,
Render animation
notice difference in the two.
T76353Stereoscopy.blend
bug reportstereoscopy.blend0001-0250.mkv
Added subscriber: @arturmachura
bug.blend
Added subscriber: @ankitm
animation of stereoscopy button doesn't workto Keyframes with stereoscopy button doesn't work in animation, individual frame worksanimation also seems to depend on the active frame in viewport. The modified steps show that.
Added subscriber: @ChristopherAnderssarian
I've used this option to cut down on render times for scenes that I didn't need to see the stereo for, at the time. It was on a render farm so each .blend file was opened on the frame that needed to be rendered so animation worked.
I hope this option doesn't get removed.
This has never worked. I tested with both 2.75a, which introduced Stereoscopy under the name "Multi-Views", and 2.79 for good measure. From what I can see in the code, it also wasn't designed with animation of this property in mind. The setting affects things like the output format; after all, if you're rendering to a side-by-side image, the output is going to be twice as wide. If you turn this on and off in the middle of a video stream, FFmpeg likely won't be able to encode that video.
Added subscribers: @dfelinto, @brecht
@brecht @dfelinto What shall I do with this report? On one hand I want to avoid future confusion and make the Stereoscopy checkbox non-animatable. On the other hand, I don't want to break @ChristopherAnderssarian 's workflow either.
Well, I've known about this for a while and made a point not to report it, as I know it wasn't designed with animation in mind and will probably end up getting removed.
It's probably just me who has ever used this. But, considering it's been five years and only now a report has come in, can we quietly keep this?
Whether it's using blender in the "wrong way", having functionality removed (in bcon3 of all times) or getting renders unknowingly deleted; you have to admit I'm pretty good at being screwed over in my edge-caseness.
Oh, I've just remembered, @sybren. You once asked me why I didn't like the term design. I think this task and the examples I gave illustrate the troubles I have with....er.. certain things.
Are you saying you are switching between stereo and non-stereo in the middle of a shot? Or this goes along with a camera switch somehow, and what could work better is an option to enable/disable stereo per camera?
Anyway, I don't see any reason to change things in 2.83, if we remove support for animating this it would be in 2.90.
I can also think of a scenario where the user switches camera mid-shot (using markers and cameras bind to them) that could potentially also impact multi-view render. But these are really corner cases where the user should know better.
Changed status from 'Archived' to: 'Confirmed'
Also known issues are to be kept open so other users can find them. If it is to be closed as invalid then its subtype is to be kept as report.
Added subscriber: @dr.sybren
