GPencil: Stroke Placement: Canvas Is No Longer Following Cursor - 2D Animations Tab
Closed, ResolvedPublicBUG
Operating system: Windows 7 64bit Pro
Graphics card: NVIDIA GeForce 970 GTX
Broken: 2.83, 1623fdb3bc55, Beta, 2020-05-02
Worked: 2.82a
See blender file:
The Canvas is no longer following the Cursor when we set the Stroke Placement to '3D Cursor'. Instead as we move the cursor around using Shift+Right click, the canvas stays locked to the center. The only way it is partially working correctly is if we switch the Drawing Plane to Cursor. All of the other Drawing Plane options do orient the rotation of the canvas correctly but it stays locked to the center instead.
I noticed this while following Dedouze's grease pencil tutorial while using 2.83. Please view this timestamped youtube video of him demonstrating in 2.82 what it should do, but this now appears to be broke in 2.83.
https://youtu.be/c57qq2nE3B0?t=970
In 2.82a the canvas will follow the cursors position
In 2.83 the canvas does not follow the cursors position
Note:
Additionally, there is what seems to be a display bug where the canvas plane is no longer able to be viewed through objects/x-ray, which is even more important. I will make a separate ticket for this though. https://developer.blender.org/T76366
  1. Create a new basic scene.
  2. Add a Grease Pencil > Blank object.
  3. Set Viewport shading to Rendered
  4. Click Overlays dropdown and enable both Canvas and 3D Cursor
  5. Click the Stroke Placement dropdown and choose '3D Cursor'
  6. move the 3D Cursor to a place on the screen other than the default center. Notice that no matter where you move it the canvas stays in teh center.
  7. Change the Drawing Plane settings to Front, Side, or Top. Notice that the canvas stays in the center.
  8. Change the Drawing Plane setting to Cursor. notice the canvas finally jumps to the cursor.
dupoxy added a subscriber: dupoxy.EditedMay 3 2020, 10:33 AM
I can confirm the change in behavior.
@shanenewville@gmail.com (Ghost_Train) please add the "Grease Pencil" tag to this report.
Edit: Please recheck your .blend file there is no Grease Pencil object in it.
the file with a grease pencil object :
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.May 3 2020, 11:19 AM
I just tested with 2.83 and for me works perfect.
Antonio Vazquez (antoniov) renamed this task from Stroke Placement: Canvas Is No Longer Following Cursor - 2D Animations Tab to GPencil: Stroke Placement: Canvas Is No Longer Following Cursor - 2D Animations Tab .May 3 2020, 4:15 PM
@shanenewville@gmail.com (Ghost_Train) Looking at your first screenshot you are mixing the location of the stroke (left dropdown) with the drawing plane possition (right dropdown). Look at my video above^^
dupoxy added a comment.May 3 2020, 6:47 PM
From what I understand the change in behavior is:
open the same file in blender 2.82 and 2.83
file:
in 2.82 :
in 2.83 :
Antonio Vazquez (antoniov) changed the task status from Needs Information from User to Confirmed.May 3 2020, 8:17 PM
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Bug".
Sorry, you are right.
@Matias Mendiola (mendio) Can you check this?
yes, something has changed after the refactor. The canvas is not working well
