Cycles fails to compile opencl kernel
Closed, ResolvedPublicBUG
Operating system: Linux-5.6.10-custom-x86_64-AMD_A8-5600K_APU_with_Radeon-tm-_HD_Graphics-with-slackware-14.2 64 Bits
Graphics card: AMD Radeon (TM) RX 480 Graphics (POLARIS10, DRM 3.36.0, 5.6.10-custom, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.2
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-05 22:28, hash: rBc036ef136960
Worked: a version from couple of days ago worked fine, ver 2.82 works as well.
Cycles fails to compile opencl kernel.
It fails on the default cube scene .
Logs
./blender --debug-cycles
Read prefs: /home/sanjuro/.config/blender/2.83/config/userpref.blend
found bundled python: /opt/applications/blender-2.83-c036ef136960-linux64/2.83/python
I0506 10:50:55.780392 2271 blender_python.cpp:191] Debug flags initialized to:
CPU flags:
AVX2 : True
AVX : True
SSE4.1 : True
SSE3 : True
SSE2 : True
BVH layout : BVH8
Split : False
CUDA flags:
Adaptive Compile : False
OptiX flags:
CUDA streams : 1
OpenCL flags:
Device type : ALL
Debug : False
Memory limit : 0
I0506 10:51:14.656942 2271 device_cuda.cpp:56] CUEW initialization failed: Error opening the library
I0506 10:51:16.374800 2271 device_opencl.cpp:48] CLEW initialization succeeded.
I0506 10:51:16.448984 2271 opencl_util.cpp:945] Enumerating devices for platform AMD Accelerated Parallel Processing.
I0506 10:51:16.449033 2271 opencl_util.cpp:981] Using more readable device name: AMD Radeon (TM) RX 480 Graphics
I0506 10:51:16.449050 2271 opencl_util.cpp:983] Adding new device AMD Radeon (TM) RX 480 Graphics.
I0506 10:51:17.432133 2271 util_task.cpp:329] Creating pool of 4 threads.
I0506 10:51:17.432173 2271 util_task.cpp:241] Detected 4 processors in active group.
I0506 10:51:17.432196 2271 util_task.cpp:251] Not setting thread group affinity.
I0506 10:51:17.433156 2271 device_opencl_impl.cpp:639] Creating new Cycles device for OpenCL platform AMD Accelerated Parallel Processing, device AMD Radeon (TM) RX 480 Graphics.
I0506 10:51:17.583458 2271 opencl_util.cpp:298] OpenCL program split_subsurface_scatter not found in cache.
I0506 10:51:17.675879 2271 opencl_util.cpp:298] OpenCL program split_subsurface_scatter not found on disk.
I0506 10:51:17.675966 2271 opencl_util.cpp:298] OpenCL program split_direct_lighting not found in cache.
I0506 10:51:17.676230 2356 opencl_util.cpp:298] OpenCL program split_subsurface_scatter not found in cache.
I0506 10:51:17.755847 2271 opencl_util.cpp:298] OpenCL program split_direct_lighting not found on disk.
I0506 10:51:17.755939 2271 opencl_util.cpp:298] OpenCL program split_indirect_background not found in cache.
I0506 10:51:17.756111 2371 opencl_util.cpp:298] OpenCL program split_direct_lighting not found in cache.
Cycles: compiling OpenCL program split_subsurface_scatter...
I0506 10:51:17.776859 2356 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
I0506 10:51:17.830255 2271 opencl_util.cpp:298] OpenCL program split_indirect_background not found on disk.
I0506 10:51:17.830617 2380 opencl_util.cpp:298] OpenCL program split_indirect_background not found in cache.
I0506 10:51:17.840534 2271 opencl_util.cpp:298] OpenCL program split_do_volume not found in cache.
Cycles: compiling OpenCL program split_direct_lighting...
I0506 10:51:17.880977 2371 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
I0506 10:51:17.938980 2271 opencl_util.cpp:298] OpenCL program split_do_volume not found on disk.
I0506 10:51:17.939067 2271 opencl_util.cpp:298] OpenCL program split_shader_eval not found in cache.
I0506 10:51:17.939131 2381 opencl_util.cpp:298] OpenCL program split_do_volume not found in cache.
I0506 10:51:18.016666 2271 opencl_util.cpp:298] OpenCL program split_shader_eval not found on disk.
I0506 10:51:18.016773 2271 opencl_util.cpp:298] OpenCL program split_lamp_emission not found in cache.
I0506 10:51:18.111045 2271 opencl_util.cpp:298] OpenCL program split_lamp_emission not found on disk.
I0506 10:51:18.111166 2271 opencl_util.cpp:298] OpenCL program split_holdout_emission_blurring_pathtermination_ao not found in cache.
I0506 10:51:18.183953 2271 opencl_util.cpp:298] OpenCL program split_holdout_emission_blurring_pathtermination_ao not found on disk.
I0506 10:51:18.184069 2271 opencl_util.cpp:298] OpenCL program split_shadow_blocked_dl not found in cache.
I0506 10:51:18.251524 2271 opencl_util.cpp:298] OpenCL program split_shadow_blocked_dl not found on disk.
I0506 10:51:18.251632 2271 opencl_util.cpp:298] OpenCL program split_shadow_blocked_ao not found in cache.
I0506 10:51:18.330969 2271 opencl_util.cpp:298] OpenCL program split_shadow_blocked_ao not found on disk.
I0506 10:51:18.331269 2271 opencl_util.cpp:298] OpenCL program split_bundle not found in cache.
I0506 10:51:18.421718 2271 opencl_util.cpp:298] OpenCL program split_bundle not found on disk.
I0506 10:51:18.422175 2271 device_opencl_impl.cpp:920] Buffer allocate: RenderBuffers, 43,206,144 bytes. (41.20M)
I0506 10:51:18.469211 2271 device_opencl_impl.cpp:920] Buffer allocate: display buffer half, 21,603,072 bytes. (20.60M)
I0506 10:51:18.936722 2440 session.cpp:803] Requested features:
Experimental features: Off
Max nodes group: 0
Nodes features: 0
Use Hair: False
Use Object Motion: False
Use Camera Motion: False
Use Baking: False
Use Subsurface: False
Use Volume: False
Use Branched Integrator: False
Use Patch Evaluation: False
Use Transparent Shadows: False
Use Principled BSDF: True
Use Denoising: False
Use Displacement: False
Use Background Light: True
I0506 10:51:18.937978 2440 device_opencl_impl.cpp:759] Loading kernels for platform AMD Accelerated Parallel Processing, device AMD Radeon (TM) RX 480 Graphics.
I0506 10:51:18.938197 2440 opencl_util.cpp:298] OpenCL program base not found in cache.
I0506 10:51:18.974778 2440 opencl_util.cpp:325] Build options passed to clBuildProgram: '-cl-no-signed-zeros -cl-mad-enable -D__KERNEL_OPENCL_AMD__ -D__KERNEL_CL_KHR_FP16__ '.
I0506 10:51:18.980587 2440 opencl_util.cpp:298] Loaded program from /home/sanjuro/.cache/cycles/kernels/cycles_kernel_base_3E07356B4B46689D30DE1E70918B033E_E853A8238BDD0E253C66384B1C685DD7.clbin.
I0506 10:51:18.980692 2440 opencl_util.cpp:298] OpenCL program background not found in cache.
I0506 10:51:19.082490 2440 opencl_util.cpp:298] OpenCL program background not found on disk.
I0506 10:51:19.082655 2440 opencl_util.cpp:298] OpenCL program split_shader_eval not found in cache.
Cycles: compiling OpenCL program split_indirect_background...
I0506 10:51:19.091385 2371 opencl_util.cpp:298] Separate-process building of /home/sanjuro/.cache/cycles/kernels/cycles_kernel_split_direct_lighting_4A526F5A1C1A408546E0B35129173E30_4A9D816F3C0CD3D5C15703F8E549BE09.clbin failed, will fall back to regular building.
I0506 10:51:19.091435 2380 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
Cycles: compiling OpenCL program split_do_volume...
I0506 10:51:19.146499 2356 opencl_util.cpp:298] Separate-process building of /home/sanjuro/.cache/cycles/kernels/cycles_kernel_split_subsurface_scatter_4A526F5A1C1A408546E0B35129173E30_3ECCEE227BE1374E6C35F161F5BA9E5B.clbin failed, will fall back to regular building.
I0506 10:51:19.146566 2381 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
I0506 10:51:19.216847 2371 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
I0506 10:51:19.216900 2371 opencl_util.cpp:325] Build options passed to clBuildProgram: '-cl-no-signed-zeros -cl-mad-enable -D__KERNEL_OPENCL_AMD__ -D__KERNEL_CL_KHR_FP16__ -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__'.
I0506 10:51:19.239979 2356 opencl_util.cpp:298] Build flags: -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__
I0506 10:51:19.240196 2356 opencl_util.cpp:325] Build options passed to clBuildProgram: '-cl-no-signed-zeros -cl-mad-enable -D__KERNEL_OPENCL_AMD__ -D__KERNEL_CL_KHR_FP16__ -D__SPLIT_KERNEL__ -D__COMPUTE_DEVICE_GPU__ -D__KERNEL_AO_PREVIEW__ -D__NODES_MAX_GROUP__=0 -D__NODES_FEATURES__=0 -D__NO_OBJECT_MOTION__ -D__NO_CAMERA_MOTION__ -D__NO_BAKING__ -D__NO_VOLUME__ -D__NO_SUBSURFACE__ -D__NO_BRANCHED_PATH__ -D__NO_PATCH_EVAL__ -D__NO_TRANSPARENT__ -D__NO_SHADOW_TRICKS__ -D__NO_PRINCIPLED__ -D__NO_DENOISING__ -D__NO_SHADER_RAYTRACE__'.
OpenCL build failed with error CL_BUILD_PROGRAM_FAILURE, errors in console.
OpenCL program split_direct_lighting build output: source/kernel/svm/svm_voronoi.h:687:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
ccl_loop_no_unroll for (int j = -1; j <= 1; j++)
source/kernel/kernel_compat_opencl.h:46:43: note: expanded from macro 'ccl_loop_no_unroll'
#define ccl_loop_no_unroll __attribute__((opencl_unroll_hint(1)))
source/kernel/svm/svm_voronoi.h:726:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
ccl_loop_no_unroll for (int j = -2; j <= 2; j++)
source/kernel/svm/svm_voronoi.h:770:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
source/kernel/svm/svm_voronoi.h:809:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
source/kernel/svm/svm_voronoi.h:829:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
source/kernel/svm/svm_voronoi.h:859:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
source/kernel/svm/svm_voronoi.h:880:7: error: 'opencl_unroll_hint' attribute requires OpenCL version 2.0 or above
7 errors generated.
error: Clang front-end compilation failed!
Frontend phase failed compilation.
Error: Compiling CL to IR
clinfo
Number of platforms:                             1
Platform Profile:                              FULL_PROFILE
Platform Version:                              OpenCL 2.1 AMD-APP (3075.10)
Platform Name:                                 AMD Accelerated Parallel Processing
Platform Vendor:                               Advanced Micro Devices, Inc.
Platform Extensions:                           cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Number of devices:                               1
Device Type:                                   CL_DEVICE_TYPE_GPU
Vendor ID:                                     1002h
Board name:                                    AMD Radeon (TM) RX 480 Graphics
Device Topology:                               PCI[ B#1, D#0, F#0 ]
Max compute units:                             36
Max work items dimensions:                     3
  Max work items[0]:                           1024
  Max work items[1]:                           1024
  Max work items[2]:                           1024
Max work group size:                           256
Preferred vector width char:                   4
Preferred vector width short:                  2
Preferred vector width int:                    1
Preferred vector width long:                   1
Preferred vector width float:                  1
Preferred vector width double:                 1
Native vector width char:                      4
Native vector width short:                     2
Native vector width int:                       1
Native vector width long:                      1
Native vector width float:                     1
Native vector width double:                    1
Max clock frequency:                           1303Mhz
Address bits:                                  64
Max memory allocation:                         4244635648
Image support:                                 Yes
Max number of images read arguments:           128
Max number of images write arguments:          8
Max image 2D width:                            16384
Max image 2D height:                           16384
Max image 3D width:                            2048
Max image 3D height:                           2048
Max image 3D depth:                            2048
Max samplers within kernel:                    16
Max size of kernel argument:                   1024
Alignment (bits) of base address:              2048
Minimum alignment (bytes) for any datatype:    128
Single precision floating point capability
  Denorms:                                     No
  Quiet NaNs:                                  Yes
  Round to nearest even:                       Yes
  Round to zero:                               Yes
  Round to +ve and infinity:                   Yes
  IEEE754-2008 fused multiply-add:             Yes
Cache type:                                    Read/Write
Cache line size:                               64
Cache size:                                    16384
Global memory size:                            7852957696
Constant buffer size:                          4244635648
Max number of constant args:                   8
Local memory type:                             Scratchpad
Local memory size:                             32768
Max pipe arguments:                            0
Max pipe active reservations:                  0
Max pipe packet size:                          0
Max global variable size:                      0
Max global variable preferred total size:      0
Max read/write image args:                     0
Max on device events:                          0
Queue on device max size:                      0
Max on device queues:                          0
Queue on device preferred size:                0
SVM capabilities:
  Coarse grain buffer:                         No
  Fine grain buffer:                           No
  Fine grain system:                           No
  Atomics:                                     No
Preferred platform atomic alignment:           0
Preferred global atomic alignment:             0
Preferred local atomic alignment:              0
Kernel Preferred work group size multiple:     64
Error correction support:                      0
Unified memory for Host and Device:            0
Profiling timer resolution:                    1
Device endianess:                              Little
Available:                                     Yes
Compiler available:                            Yes
Execution capabilities:
  Execute OpenCL kernels:                      Yes
  Execute native function:                     No
Queue on Host properties:
  Out-of-Order:                                No
  Profiling :                                  Yes
Queue on Device properties:
  Out-of-Order:                                No
  Profiling :                                  No
Platform ID:                                   0x7f48cb9c4e50
Device OpenCL C version:                       OpenCL C 1.2
Driver version:                                3075.10
Version:                                       OpenCL 1.2 AMD-APP (3075.10)
Extensions:                                    cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_spir cl_khr_gl_event
