Calling unregister function in custom_nodes.py example
Closed, InvalidPublic
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.34
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-21 17:59, hash: rB13e3a1c53222
I'm using example from Blender scripts templates called custom_nodes.py. When I use it as it is everything is as expected. Then i'm trying to call unregister code of the same example and i'm getting next error:
  File "\custom_nodes.py", line 187, in <module>
  File "\custom_nodes.py", line 183, in unregister
RuntimeError: unregister_class(...):, missing bl_rna attribute from 'RNAMetaPropGroup' instance (may not be registered)
I think whether it is a bug or the example is incorrect.
  • open custom_nodes.py script in text editor
  • run the script
  • rename register() to unregister() in the end of the example
  • read console
You need to register before unregister.
By renaming register to unregister you are reversing the order.
And whenever you run the script you are creating other pyobjects.
Ok, is it possible to unregister MyCustomTree class from custom_nodes.py example after this class was registered? I just can't find where Blender keep this class after registration. bpy.types looks like keeps only built in classes.
I suggest asking this on user support sites -> https://www.blender.org/support/
