Object join doesn't respect parenting #76556
7 Participants
Reference: blender/blender#76556
Operating system: Windows 10
Graphics card: NVidia GeForce Gt730
Blender 2.82A and Blender 2.83Beta 2020/05/08
When selecting two objects and doing the command Ctrl + Join they disappear.
The error occurs when selecting the smallest and then the largest object and pressing {key Ctrl J}
But when selecting the big one and then the small one the error doesn't happen.
ErrorCtrl+Join.blend
Added subscriber: @rsenas
Crash on Ctrl+Join two objects in mode object.to Objects disappear on Ctrl+Join based on order of selectionChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @ankitm
Added subscriber: @Alaska
@ankitm I don't believe this is a bug. The small object is being joined to a large object. The large object is the child of the small object and has a different position to the parent.
The objects doesn't disappear, they just shift to the location of the child object which is now "reset" because it no longer has a parent to reference it's location off of.
If you unparent the objects then join them, the issue does not occur.
Changed status from 'Confirmed' to: 'Needs Triage'
Right, I didn't check in outliner.
Added subscriber: @brecht
Changed status from 'Archived' to: 'Confirmed'
The object transform including parenting should be applied to the vertex coordinates, so that the joined vertices remain in the same location.
Always learning and being more attentive. Thank you.
Here's a simpler demonstration. The problem is a bit different with different object types.
simplescreenrecorder-2020-05-12_15.45.28.mp4
Join Parented Objects Test.blend
Objects disappear on Ctrl+Join based on order of selectionto Object join doesn't respect parent transform of child objectObject join doesn't respect parent transform of child objectto Object join doesn't respect parentingAdded subscriber: @sok0
Isn't this behavior to be expected due to the parent inverse matrix? The parent object has moved since it was parented to the child object (verified below) . As a result the child object moves back to its basis transform location when the parenting relationship is broken.
To avoid this quirk of the parent inverse matrix, there are two options:
Either way, you then can join objects with the desired result, no need to change to the join operator.
footnote:
This issue was referenced by
5e96c43854
The change is simple anyway, and avoids the need for applying the parent transform first.
