Adjust Last Operation panel is grayed out #76618
6 Participants
Reference: blender/blender#76618
Operating system: Linux-5.4.0-14-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.64
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-07 21:33, hash:
c6cda3c09c
Broken in all 2.8x too
The last operator panel only grays out if the compositor tab is open and "use nodes" is enabled. If you close the window for the compositor or turn off "Use nodes", the issue doesn't occur.
Here a video with an example with Smooth Vertices, but the problem can occur with any action showing operator panel:
operator_bug.mp4
bug_operator.blend
All fields are grayed out until cursor leaves "hot area"
Added subscriber: @YAFU
Added subscriber: @Alaska
I tested on my system. POP!_OS 20.04 (Ubuntu 20.04 based distribution) with a GTX 1050ti driver 440.82. Here's what I've found:
So for the developers, here's the exact sets to reproduce:
Oh, it was that. Thank you!
The strangest thing is that this occurs from 2.80 inclusive. I was almost certain that this could be due to a problem with KDE compositor because apparently this had not been reported and I was the only one having the problem in so long.
It's not KDE. I'm using Gnome.
It is also a kind of edge case which is why it probably hasn't been reported.
Wait. Under the same circumstances with compositor and with "Use nodes" enabled, the problem also occurs in Blender 2.7x, but only in Operator in Tool Shelf panel, not in F6 operator. Open in 2.7x:
bug_operator_2.7x.blend
The question is I don't recall having the problem. Maybe nvidia driver is also involved? Currently using 440.64 version.
Added subscriber: @iss
This seems to be more specific. Possibly only changes in edit mode?
In any case I think I can confirm this with this info
Edit: it looks like you have to click on arrow to change value to cause this
Sometimes Operator Menu becomes unresponsiveto Adjust Last Operation panel is grayed outChanged status from 'Needs Triage' to: 'Confirmed'
Another strange problem: If the redo panel is already active and you turn "Use Nodes" on, then adjusting any of the properties in the redo panel will turn "Use Nodes" off.
Added subscriber: @Jeroen-Bakker
The problem happens because the redo panel is set to disable when there's a job running, and the compositor job runs for every 3D viewport change. I'm not sure what the right solution is.
Not starting the compositor job if there's nothing to update would probably be the best way to solve this, but that seems fairly involved.
@Jeroen-Bakker This seems like it's verging on a "Known Issue," would you agree?
This is still happening by the way, 3 years later on 3.6.3.
Really glad this was the first result on google because already had another crazy bug today with autosaves.
it still happen in blender 4.0.2, here how i fix it, pick any object, enter edit mode, add a cude, the panel appear work well, exit edit mode, everything back to normal
