Node editor cannot connect nodes [2 monitors with UI scaling] #76637
6 Participants
Reference: blender/blender#76637
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: Radeon (TM) Pro WX 4150 Graphics ATI Technologies Inc. 4.5.13572 Core Profile Context FireGL 19.Q4.1 26.20.13032.13
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-06 16:18, hash:
9605c26166
Worked: Never (2.8+)
Can not connect nodes if Blender has 2 windows with node editor open on 2 monitors with mismatching resolution
Bug should be reproducible on following setup:
Primary monitor: FHD, 100% scaling, child window, nodes working OK
Secondary monitor: 4K 150% scaling, main window, can't connect nodes here.
Added subscriber: @PGT2
Added subscriber: @brecht
I can't reproduce this problem.
Please attach an example .blend file saved with two windows and node editors open where it's not possible to connect nodes.
Added subscriber: @Alaska
I am also unable to reproduce this issue.
I also worked on a few projects a couple months ago that required me to have multiple node editors open in multiple windows on multiple monitors and I never had this issue. Although, that may of been down to me using Blender 2.82a or 2.81.
node-editor.blend
Ok i notice it doesnt happen allways.
Here i tried it a few times till it happened in the main window. (you need 2 screens maybe to get it).
The main window cannot connect nodes in this blend file
In above file, started mainwindows 3dview+nodes side by side.
Duplicated screen (didnt happen then),
Then turned the seccond monitor (not main) nodes into 3dview
Then i vertically split left side of the (not main) and turned the upper in nodes view.
Then i couldnt connect nodes in the main windows
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
I tested with your file. Tried creating many more windows, splitting 3D views and turning them into node editors, etc. Still unable to reproduce.
I'm using Blender 2.83
eaee2b4119
(2020-05-10 06:26) on Linux with a GTX 1050ti. I don't know if using Linux or a Nvidia GPU changes anything (it probably won't), but it's something to keep in mind.I tested it with blender 2.9 as well still the same problem in that file.
So you were able to connect or alter the node setup in both node views, i'm not.
Added subscriber: @iss
Do you use 2 monitors? Are they same brand / resolution / DPI scaling?
Can you cause this error when both windows are in same monitor?
I was able to connect and alter the nodes in both views.
Have you tried loading factory defaults then attempting to recreate the issue? Select from the top of Blender "File>Defaults>Load factory settings" then attempt to recreate the issue from there.
I doubt it will work, but it's worth trying.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
I checked quickly if resolution matters here (of course after I requested this info...) and I can cause this issue.
My setup was:
Though I have a feeling I have seen this issue reported, but I can not find this report.
Removed subscriber: @Alaska
Ok i can confirm its combined problem with windows monitor scaling,
Windows uses a recomended scale here ( note that I also wear glasses, my eyesight isnt perfect anymore ) so If i disable it, it becomes too small for my eyes.
I have to set my laptop on 125% and a philips monitor on 100%, and those seam the default for both.
Node editor cannot connect nodesto Node editor cannot connect nodes [2 monitors with UI scaling]Added subscriber: @lichtwerk
Looks like the same as #74355 (Selecting (or connecting) nodes in Compositor is malfunctioning when when monitors have different dpi)...
Closed as duplicate of #74355
Lets continue discussion in #74355...
Added subscriber: @DuarteRamos
This seems to be similar or the same underlying issue as
