Crash when changing Size in Add Cube pop-up #76646
5 Participants
Reference: blender/blender#76646
Operating system: Windows 10 x64 (1909)
Graphics card: Asus GeForce RTX 2080ti (latest GeForce Experience NVIDIA Studio Driver 442.92)
Broken:
2.90,
51ac411ce8
, master, 2020-05-10 15:422.83,
eaee2b4119
, master, 2020-05-10 06:26Worked: 2.82
Mouse-dragging the Size setting in the Add Cube popup causes Blender to crash. Both 2.83 and 2.90 daily build seem to exhibit the same issue.
I was getting CTD when using the Redo Last (Shift-R) shortcut when using a custom Transform Orientation. I hit this crash when trying to reproduce that. Unsure if the two are related.
Crash logs from 2.90 build:
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @browneggz
Can confirm this, and also that I had to reset to default preferences to cause it.
Added subscriber: @mont29
@mont29 This looks like an undo related crash. Maybe related to
c43725e189
This seems like quite a corner case though, because it only occurs right after resetting to factory settings. Starting Blender again after resetting to default settings does not cause the crash.
Added subscriber: @brecht
The issue is that
BKE_lib_libblock_session_uuid_reset
is being called when resetting preferences to factory settings, even though the .blend file and datablocks remain unchanged. I also noticed thatWM_file_read
callsBKE_lib_libblock_session_uuid_reset
before it is certain that a new file will be loaded.Could we just remove
altogether? The UUID wraps around anyway, so I'm not sure there's anything to be gained from resetting it to zero.@brecht yes, think it simpler to just remove it altogether, it might be a bit tricky to do those calls always at proper place, and they do not bring any added value anymore...
This issue was referenced by
cda25f8f38
