'Reset to Default Value' sets any property on a node to 0
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Worked: Never
In shader editor gamma default is 1 when I do the hover over setting and press backspace to reset the default it goes to 0.0
Same with hue/saturation/value.. and probably more.
The one with hue is pretty annoying as it has specific default settings .
Same deal with groups - I set the defaults, it doesn't default .. goes to 0
  • in any node editor hover over any setting and press backspace to reset to default value.
It defaults to 0 instead of 1 or whatever it's default was in shader editor..
This isn't limited to Windows and it isn't limited to this node (I think all shader nodes have this issue). (Repro'd on a Mac in, e.g., the World Diffuse BSDF shader parameters.)
I'm a complete Blender dev newbie, but with a little guidance I'd be happy to try pushing a patch for this!
Germano Cavalcante (mano-wii) renamed this task from reseting defaults via backspace hover going to 0 instead of actual defaults to 'Reset to Default Value' set any property on a node to 0.May 13 2020, 7:44 PM
Germano Cavalcante (mano-wii) renamed this task from 'Reset to Default Value' set any property on a node to 0 to 'Reset to Default Value' sets any property on a node to 0.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
it's probably spread out all over the interface - I was building a node group, and almost each setting has a different default - I changed all the default values - and even in group nodes it just goes to 0, instead of 1, 0.5 etc.. so I'm not sure that even the one for node groups work - or does it reflect the ones from the nodes that are inside the node groups ..
Wouldn't be a big bother, but I keep on reloading the original nodes bcs I keep forgeting what the defaults are..
Germano Cavalcante (mano-wii) changed the subtype of this task from "Bug" to "Known Issue".May 14 2020, 3:57 PM
