Texture with alpha renders differently in Eevee and Cycles #76712
Closed
opened 2020-05-13 09:34:41 +02:00 by Zsolt Stefan · 16 comments
Graphics card: GeForce RTX 2080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-01 21:55, hash: 83304e4c22
I have a PNG texture with an alpha channel, plugged into the FAC input of a mix node. To switch between two shaders and show a pattern on the object surface.
In Eevee, the alpha map is used, and the texture appears on the surface. The cycles rendering is different, the pattern is not shown.
I don't know which one is the intended behaviour, but in any case eevee and cycles shouldn't render differently.
Related bug: there is a node attached to the alpha output of the texture, it is however not used for anything right now. If I however delete it, unconnect and reconnect the nodes, then eevee also stops using the alpha channel.
An unused node should have no effect on the output.
  • Open the attached BLEND.
  • Switch to Material Preview. The surface has a pattern on it.
  • Switch to Cycles. The surface has no pattern.
  • Switch back to Material Preview. Delete or unconnect the unused "Invert" node in the Shader Editor.
  • Nothing happens.
  • Unconnect the Texture Colour Output connection to the Fac Input of the Mix Shader node.
  • Reconnect the same connection.
  • Now the pattern has disappeared.
Texture_with_alpha_renders_differently_bug.blend
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19 **Blender Version** Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-01 21:55, hash: `83304e4c22` Worked: (newest version of Blender that worked as expected) **Short description of error** I have a PNG texture with an alpha channel, plugged into the FAC input of a mix node. To switch between two shaders and show a pattern on the object surface. In Eevee, the alpha map is used, and the texture appears on the surface. The cycles rendering is different, the pattern is not shown. I don't know which one is the intended behaviour, but in any case eevee and cycles shouldn't render differently. Related bug: there is a node attached to the alpha output of the texture, it is however not used for anything right now. If I however delete it, unconnect and reconnect the nodes, then eevee also stops using the alpha channel. An unused node should have no effect on the output. **Exact steps for others to reproduce the error** - Open the attached BLEND. - Switch to Material Preview. The surface has a pattern on it. - Switch to Cycles. The surface has no pattern. - Switch back to Material Preview. Delete or unconnect the unused "Invert" node in the Shader Editor. - Nothing happens. - Unconnect the Texture Colour Output connection to the Fac Input of the Mix Shader node. - Reconnect the same connection. - Now the pattern has disappeared. [Texture_with_alpha_renders_differently_bug.blend](https://archive.blender.org/developer/F8532574/Texture_with_alpha_renders_differently_bug.blend)
Author
Added subscriber: @ZsoltStefan
Member
Added subscriber: @Alaska
Member
@ZsoltStefan To reproduce the bug with your .blend you need to pack all the textures into the .blend file. To do this, select from the top of Blender "File>External Data>Pack all into .blend" then save the file and re-share it.
Member
Author
Oh, right, reuploaded.
Member
Member
@ZsoltStefan Thank you. As for your report about the bug, I can confirm this happens. Tested with Blender 2.82a and 2.90 f9d0f59bed (2020-05-12 22:14) with a GTX 1050ti driver version 440.82 on Linux.
Member
Member
Added subscriber: @ankitm
Added subscriber: @brecht
Brecht Van Lommel self-assigned this 2020-05-13 15:20:44 +02:00
There is an intentional difference between Cycles and Eevee here, for reasons of performance and compatibility with game engines vs. offline renderers.
Some background on this is in #64625.
There is an intentional difference between Cycles and Eevee here, for reasons of performance and compatibility with game engines vs. offline renderers. Some background on this is in #64625.
Changed status from 'Resolved' to: 'Archived'
Member
Added subscriber: @EAW
Member
If you want to use the Alpha channel as a pattern, you should connect the alpha channel to the factor, not the color.
Texture_with_alpha_renders_differently_FIXED.blend
![Cycles.jpg](https://archive.blender.org/developer/F8536210/Cycles.jpg) Cycles ![EEVEE.jpg](https://archive.blender.org/developer/F8536212/EEVEE.jpg) EEVEE If you want to use the Alpha channel as a pattern, you should connect the alpha channel to the factor, not the color. [Texture_with_alpha_renders_differently_FIXED.blend](https://archive.blender.org/developer/F8536230/Texture_with_alpha_renders_differently_FIXED.blend)
Author
@EAW thanks for the reply. I am aware how to solve the problem, I was trying to address these two bugs:
  1. Eevee ("Material Preview") doesn't always "preview" a material in cycles. As Brecht says, in this case this seems to be intentional.
  2. An unused node has an effect on the output. Don't see why this would be intentional.
@EAW thanks for the reply. I am aware how to solve the problem, I was trying to address these two bugs: 1. Eevee ("Material Preview") doesn't always "preview" a material in cycles. As Brecht says, in this case this seems to be intentional. 2. An unused node has an effect on the output. Don't see why this would be intentional.
5 Participants
Reference: blender/blender#76712
