Baking 'Selected to Active' ignores particle instances #76864
Reference: blender/blender#76864
Operating system: Linux-5.3.18-050318-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.64.00
Broken: version: 2.90 (sub 2), branch: master, commit date: 2020-05-18 15:35, hash:
35f9c3b9a4
Worked: Apparently never
I try to bake normals from an object with particles (rendered as a collection containing a single cube) to a simple plane.
During baking the particle instances aren't "seen" by the baker.
Even if I convert the particles to instances, the baking fails.
Only if I join all the cubes into one single object (CTRL+J) the baking produces the expected result:
The texture in the upper left Image Editor turns grey.
Baking_Problem_v01.blend
Added subscriber: @SteffenD
Added subscriber: @iss
Can you upload 2.7 file that works?
Sadly no, it seems.
First I recreated a similar scene as above in 2.79 last nightly -> it crashed
2.79b final didn't crash but also didn't "see" the instanced cubes. It rendered an empty grey map.
I remember that I once did it, maybe in an even earlier version of Blender (that's why I added "IIRC" to the version that worked).
Sadly it turns out to not work in 2.79 and in 2.8x.
I asked only because I wouldn't expect this to work
I have been able to bake normals, if I used Particle Instance modifier on cube, and then baked cube to target, which is essentially what you did, but a bit more procedural. Perhaps this was also a method that worked prior to 2.8?
Ah OK, that might be it... I'll give it a try with 2.79 and 2.8x / 2.90 soon.
EDIT: Yes, it works in 2.8x / 2.90 when using the Particle Instance modifier.
Particle instances aren't rendered during bakingto Baking 'Selected to Active' ignores particle instancesChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @mano-wii
I tested in versions 2.73 and 2.79 but the problem is also seen in them.
Here is the file for blender 2.73:
Baking_Problem_2_73.blend
Closed as duplicate of #43553
