DXF importer creates bad arcs representation #76908
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#76908
Operating system: Linux-5.6.11-050611-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX TITAN X/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.64
Broken: v2.82, v3.2
Worked: Never
Arcs are improperly converted to curves when imported from DXF, they are not perfectly circular.
The DXF specification doesn't mandate the use of any curve type, it just says that there is an arc with a specific radius, center, and angle. How the software draw or represents that arc is up to it. Currently, the importer represents arcs as Bezier curves, but it computes their handles wrong, which is what the report demonstrates. So a fix would then change the importer to compute the bezier handle correctly. However, as suggested by the user, since NURBS can represent arcs better (Bezier curves are approximations), then it maybe worth it to change the importer to import NURBS instead.
See http://docs.autodesk.com/ACD/2011/ENU/filesDXF/WS1a9193826455f5ff18cb41610ec0a2e719-7a35.htm.
I have created a simple DXF file containing one circle and one arc. Both have common center at point [0,100] and radius 100. If I import them by Blender importer, the resulting arc does not match the circle.
dxf_import-01.dxf dxf_import.blend
Added subscriber: @VaclavCermak
Added subscriber: @rjg
How did you create the
*.dxf
file and are you certain that your expectation with regards to the arc are valid according to the file format specification?DXF was simply drawn in BricsCAD (https://www.bricsys.com) and exported from it. So I assume that the file is valid, but I haven't checked it except reopening in BricsCAD.
Added subscriber: @OmarEmaraDev
The imported files looks like this for me. There is a tiny difference at 270, and that difference exist when I tested the files on other software. So this doesn't seem like a Blender specific issue.
Is this the difference you are describing?
Yes, its probably that difference. The curve should go exactly through [0, 0] point and it does not.
To be honest, I created it two years ago and I don't remember the exact reason for reporting it. It was probably when I imported some site plan with lot of detailed roads and their arcs were somewhat misplaced and didn't fit to other parts of that plan.
The difference looks much larger in Blnder when compared to other software indeed. So looks like an import issue.
I'am not sure, if a circular arc can be exactly represented by bezier curves at all (I think not), so it may be fundamental problem, not some bug in calculating curve coeficients. It may be solved by using nurbs curves instead bezier ones then.
That is true, but small arcs can be approximated very well with bezier curves, so I doubt this is an intrinsic limitation.
Agreed, but...
At first, something convinced me to create this task. Unfortunately I can't remember what it was exactly. But it means, that there was a situation, when this limitation had its own impact.
And second, is there any reason not to use nurbs? When we have the opportunity to represent imported geometry exactly, why not to use it?
As for that "impact", if I import a site plan, arcs forming roads have typically big sizes. Even with small error they may be misplaced from other point element imported from the same site plan (trees, streetlights etc.) significantly. Maybe this was the problem.
Now I'am converting all arcs and circles to polylines with some CAD utility before import to Blender, so I haven't met this problem for a while. It is clumsy, however.
Perhaps Nurbs could be used as a better option, but that is up to the maintainers of the add-on, so we should just wait and see what they think about that.
Or we may try to dive into it and create a patch, it shouldn't be so hard ;-) But first I want to discuss, if there are any reasons not to use nurbs. Maybe I'am missing something.
@VaclavCermak Feel free to try to create a patch that uses NURBS to import acrs to fix this issue. Or if proven harder than expected, maybe try fixing the bezier computations first. Let us know if you need any help doing that.
Fine, I'll try that. I have looked into the source and I think that I know how and where I should add it.
