Random Crashes: when saving .blend file and when opening image from image editor
Closed, DuplicatePublicBUG
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54
Broken: version: 2.90 (sub 2), branch: master, commit date: 2020-05-20 08:43, hash: rB578b0c00cacb
Random Crashes when saving .blend file and when opening image from image editor
Scenario 1:
  • Start a new Blender project then save it, the blend file will be save but it will crash.
  • It should crash if not try again.
Scenario 2:
Open an image with image editor by:
    • doing ctrl+f10 in the outliner window
  • then click open
The problem with randoms crash i have to upload a video
I cant reproduce the problem.
Can you run blender_debug-gpu.cmd that is included in the download.
After Blender closes, the logs will be in a text file which can be attached here.
Here is you go:
  • With debug version
  • And with release version, not debug.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Fri, May 22, 2:18 PM
Germano Cavalcante (mano-wii) triaged this task as High priority.
Apparently it is not a GPU problem.
Reading Stack trace I suspect the problem is that region has an invalid memory address (in handler_region_v2d_mask_test).
@Erick Tukuniata (erickblender), which of the described scenarios did you use to generate crash.txt?
I cannot reproduce the problem, but I'm confirming it.
