smoke not rendered in viewport after rebaking #76938
Reference: blender/blender#76938
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.83 (sub 17), branch: master, commit date: 2020-05-19 23:15, hash:
dfe8195dfe
Worked: not known
Smoke is not rendered in viewport rendering using cycles
Added subscriber: @jdk
Added subscriber: @iss
After decreasing From Min value of Map Range nodes in step 8, I can see smoke being rendered.
I do not see a bug here. Your node setup removes all smoke that is less dense than
0.91
. The simulated smoke simply does not become dense enough to be visible with your node setup. It works in solid mode, because there a different shader is used for the smoke.I confirmed this because step 3 and 4 are true and should not be.
Why should steps 3 and 4 not work?
Because when you rebake, the smoke stops being visible. I think step 6 is not necessary here. I should have edit these steps. Will go over this again and edit description.
@JacquesLucke Nevermind my comments, I must have been confused with some other tests I have done. Behavior indeed looks correct, and dissolve will affect density to extent that it is not rendered with shader provided.
