Crash during render with frame_change_post handler updating materials #77038
Reference: blender/blender#77038
Operating system: Ubuntu 18.04.4 LTS Linux-4.15.0-96-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2) Intel Open Source Technology Center 4.5 (Core Profile) Mesa 19.2.8
Broken: version: 2.90 (sub 3), branch: master, commit date: 2020-05-24 21:18, hash:
5db2d9c82b
Also tested in blender 2.82a on same system, same problem, so it's been in since at least then.
Open the provided blend file, enable running of scripts, press ctrl-F12 to render the animation. After maybe doing some rendering, blender crashes with a segfault. (try a few times if render succeeds at first, crash is non deterministic)
Provided blend file uses cycles, render engine can also be set to eevee or workbench, problem still occurs.
The scene is updated on each frame change by a small python script. In a
frame_change_post
handler, the script looks for objects with a custom property called 'num' and updates the materials on any child with a name of the form Dot[1-10]. such that one of them has the "on" material, and the others have the "off" material. This script runs fine with seeking through the animation in the timeline view, and doesn't cause the crash. This can be done with the viewport in any mode (rendered or shaded, or something else but the animation is only visible in rendered or shaded modes)I'm ready to admit that there's a problem in my python script, but if there is, it's not obvious where it is, and it's not clear why it should work in the normal 3d viewport but not during render.
Regardless, It shouldn't be possible to segfault blender from a python script (without trying really hard). If this is not a bug in blender, but is a bug in the py script. then the condition for this segfault should be caught and an error message shown.
test_segfault.blend
Render animation
Crash file:
crash.txt
For reference, this is the script:
Added subscriber: @danieljabailey
Added subscriber: @iss
Can confirm crash, run with different settings and I am getting consistently this stack trace:
Main:
Thread(crashed):
id->cow
was nullptrNon deterministic segfault during render when a python frame_change_post handler updates materialsto Crash during render with frame_change_post handler updating materialsAdded subscriber: @dr.sybren
This is a known issue, described in the Application Handlers: Note on Altering Data section of the Python API docs.
In short: there are two dependency graphs being evaluated at the same time (one for the viewport, and the other for the render). Changing Blender data is not thread-safe, hence when that is done from a
frame_change_post
handler, it can cause problems. The solution is to lock the interface (Render → Lock Interface).Ah thanks for info, I did not know this. Will keep in mind for future.
I don't think this is an invalid bug report.
Sure it's a known issue, and it's documented, but it's not likely that any user is going to find that documentation upon encountering what appears to be a random segfault.
It shouldn't be possible to segfault blender from within a python script without deliberately trying to do it.
So, I would propose that at least one of the following things happens:
Ideally I'd like to see option 1 happen, but I have no idea how complicated that solution could be. I'm guessing it would be quite complicated.
Option 2 feels like a much easier one to implement, but could still be tricky. At least it would have the benefit of avoiding crashing the whole of blender, and make it obvious what to do to workaround the problem.
Option 3 should be the easiest of the three, and would go someway towards fixing this problem, but still won't provide obvious error messages. In general though I think this could be helpful for other possible segfaults, suppose raising a "BlenderInternalSegfault" exception (for example) in python land. This would enable some level of recovery from this and other bugs, and make it obvious that it was a problem in the python code that caused the issue, and not a problem in blender. Option 3 could also be implemented even if one of the other two is also implemented.
This is not the first time I've encountered a segfault caused from python code.
I would love to help implementing any of these three solutions, if there is enthusiasm to merge such a fix.
Thoughts?
Thanks.
The root cause of the thread-unsafety is the multi-threaded nature of the dependency graph evaluation. This is necessary to get a decent performance on modern multi-core/multi-threading CPUs. This can be resolved by adding mutexes/locks, but that will reduce Blender's performance. In a similar way, refusing to change data from Python when "Lock Interface" is disabled would require a check on each and every data change. This is also very likely to cause performance issues. The last option also isn't that easy, as it requires clean handling of a segmentation fault (which isn't possible except with rather hacky code). I'm happy to be proven wrong here, though.
@dr.sybren After a little bit of reading the python C api docs, I've found it to be fairly easy to generate a python backtrace upon a segfault. And given that it's easy to catch a segfault (in linux at least, I haven't tried windows) without doing anything hacky, I have been able to get blender to provide a python backtrace when python code causes a segfault.
https://developer.blender.org/differential/diff/27377/
Would you mind taking a look at this patch and letting me know what you think of it?
It almost certainly doesn't work on windows, so the patch will need some work on that front.
Also, I'm not sure what the normal etiquette is on blender's phabricator is, should I open another ticket for this? (It's related to this issue, but it's also just the addition of a debugging feature)
Previously I would get this output on a segfault:
This patch enables me now to have some clue of where the problem occurred.
Better link, now that I've figured out how phabricator works 😁
https://developer.blender.org/D8457
We can discuss the patch at D8457, no need to open another ticket.
