QuadRemesher plugin crashes Blender 2.83 and 2.9 on Windows (in python code that hides and import a fbx) #77046
5 Participants
Reference: blender/blender#77046
Operating system: windows
Graphics card: nvidia
Broken: 2.83 and 2.90
Worked: 2.82a
Hello,
I'm the developer of QuadRemesher (an automatic quad remeshing addon for Blender).
My addon (v1.0) is working well in 2.82 but crashes blender 2.83 and 2.9.
I found a workaround (in QR 1.1 CR3) but I think the crash needs to be fixed inside Blender to improve Blender stability.
My addon basically works like this: when you press "Remesh It", it:
This is crashing Blender 2.83 and 2.90 in the 3rd step (hide and import)
The workaround is just to switch the order of "hiding" and "importing" operations.
So in 1.1 CR3 I do : "imports" the retopoFile and then "hides the previously selected object".
With this order, Blender 2.83 / 2.90 is not crashing anymore.
You will have to download and install my plugin : https://exoside.com/quadremesher/quadremesher-download/
(use the 1.0 if you want to reproduce the crash)
Once installed (see https://youtu.be/6BvP3rXeRRI),
you just need to click on "Remesh It" button with the "starting" Cube selected
The issue is in function doRemeshing_Finish (see "hide_set" and "import_mesh_fbx" calls)
Added subscriber: @Max33
Added subscriber: @lichtwerk
Can this be reproduced with a simpler setup? (I assume this is not depending on the export as well as the remeshing at all?)
So something like this:
This will help reduce the time reproducing and tracking down the issue, thx in advance!
OK.
Here is a simple script that crashes Blender 2.83 and 2.90:
I call this function in the execute() function of an operator.
Just call it with the cube which is created when Blender starts.
def test_crash():
sel_objects = bpy.context.selected_objects
if len(sel_objects) != 1:
return
input_obj = sel_objects[0]
And this one works:
def working_case():
return
Added subscriber: @filibis
Cannot reproduce here.
Checked in both 2.83 and 2.90 buildbot builds with this file:
#77046.blend
Just to be really sure: does it crash with the file above for you?
Yes it works if you run it outside of an operator.
But, as described in my previous message, it crashes when launched inside an operator execute() method. (at least on my computer with 2.83 and 2.90)
I attached an addon which allows to reproduce the crash.
(put it in the scripts/addons folder, enable it in the Prefs / Addons, hit 'N', open the QRTestCrash tab, click on <>)quad_remesher_crash.zip
Also no crash here with the Addon you provided.
(I had to change
myfilepath
in the script to something writable on linux, but no, no crash here)Do you have the chance to test this on another machine?
You could also check if there are possibly other Addons interfering?
File
>Defaults
>Load Factory Settings
and only enable that one Addon?I tested on Linux. It works on my Linux.... but not on my Windows 10....
Can you test on Windows ?
Added subscriber: @ideasman42
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Needs developer to test on windows.
QuadRemesher plugin crashes Blender 2.83 and 2.9 (in python code that hides and import a fbx)to QuadRemesher plugin crashes Blender 2.83 and 2.9 on Windows (in python code that hides and import a fbx)Added subscriber: @LazyDodo
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
no repro with 2.83 or 2.90 even tried the hardened heap.
Given you have the crash with 2.90, when you run it from the command line, and it crashes it should tell you the location of the crash report (generally somewhere in the temp folder) please attach this file to this report.
This report requires far too many steps to redo, please include a sample blend file that includes a script that crashes on execution.
The simple script has already been provided (see history of this conversation : May 25, 3 PM)
And (May 28 6 PM) -> you can download the zip with the code inside...
@Max33 : please the above ^^
Hello the bug seems to be fixed.
I can reproduce the crash in 2.83 Beta (Date 2020-05-15)
And the crash doesn't happen with Blender 2.83.2 .
Changed status from 'Needs User Info' to: 'Resolved'
